29.5" mean machine Cat
  • skiaddict00
    • 21
    cool. thanks for the advice. as far as a prop and shaft i read reddy watt's mean machine setup and i'll use one of those props but would it be better to run a water penetrating prop? what are the best angles to run? any building tips will be very welcome.
    and just so you all know i ordered the blue hull and it shall be named BLUE BALLS!
    • steveo
      • 1454
      never mind
      • Piranha2
        • 320
        Here is my interpretation of how I was told to wire up my 240.....better have a sick iron!!! Do the same combining of the motor/ESC leads. I reshrinkwrapped the whole ESC to include the watercooling tubing connections.
          • 7990
          WRONG! You want to carry both positive wires to the plug, ditto the negative wires. Do not cut them short and solder them before the connectors. I strongly recommend not using a single Deans with this controller....you are compormising its amperage capacity. Either use 5.5mm gold connectors - or use one Deans for the positive side (one + wire on each tab) and another Deans for the negative.
          • Piranha2
            • 320
            10AWG only can handle 55 amps.....X2 =110amps.....Hydra 240 = 240 amps....What gauge wire do your packs have? (10AWG?) What gauge wire does your motor have? (10AWG?) The Hydra 240 is just 2 Hydra 120's piggybacked.....So the suggestion is to use 10 (?) Deans connectors? The phenomenom involved is air gap.....air is not a medium used for transmission of DC power. It is seen as an open circuit no matter how good the connector is. There is no air gap in a properly soldered joint. How come the fastest FE on the planet uses NO motor connectors? Just solder joints. I use 16-IB3600's on a 9XL and the Hydra 240 rarely goes above ambient temperature. The diagram was what a club racer suggested, my configuration was to strip one lead 3/4" and the other 1/2" resulting in a 1/2" solder joint and so that the remaining 1/4" solders to the Deans. NO matter how you wire your Hydra 240 it will NOT be the weak link in your set-up.
            • skiaddict00
              • 21
              i just ordered them from this site i would suppose that they are 10awg... they're thicker than the 12awg i bought to make a y-harness so yeah... so it's better to connect the engine to the esc with the 5mm gold connectors and the batteries with deans ultra? if i have 3 wires for the motor and 6 from the speed control how do i connect them? what is the best way? i am such a newbie.
