mgm esc infomation
  • ozzie-crawl
    • Sep 2008
    • 2943
    mgm esc infomation
    i have a mgm esc i got from a forum member. model= tmm12024-3s z series rb
    its a fantastic looking built 120a esc,just trying to find any info on them has anyone run the mgm esc,s
  • Team FFRB
    • 328
    Mgm
    Yes.
    HOT RODS ON WATER
    • m4a1usr
      Fast Electric Addict
      • 2036
      A super duty speedo. Built like a russian tank. But I recommend you ditch the 3mm bullets if yours does not have the wires soldered on. Hope fully you have the latest software installed but its more related to lipo configuration then motor performance. I have been using them for many years and its one of the few speedos that have safety features rated very conservatively. I have only sent one back for repairs and they didnt charge me a dime even though I bought the speedo damaged (didnt know it and off Ebay). I wont sell any of mine. They work flawlessly in my setups from mild to wild. I have that same speedo in an Excess 2 and its powering a 1515 1D. Its thermaled several times as I experimented with props. Once cooled the hull comes back. A very well built speedo is all I can say and I am on the prowl all the time on Ebay searching for them.
      John
      Change is the one Constant
      • Jeepers
        • May 2007
        • 2050
        I have an MGM esc this is the one I have. ( its no longer operational pushed it to hard)
        Complete range of our off-the-shelf types of electric motors, inverters / ESCs / speed controllers 3kW up to 400kW, BMSs, electronic contactors, chargers and
        Its a very smooth esc, makes the Castle's feel like a off & on switch. I had trouble programing it to a Spektrum 2.4ghz radio, had to mess with the throttle end points, once I got it armed I had no trouble with it. On the other hand it armed with out ANY problems with an Airtronics MX3 radio.
        • ozzie-crawl
          • Sep 2008
          • 2943
          the one i have has never been used,iam not sure how old it is but from what i gather on mgms site it is setup for lipos.
          it will be going in my vs1 running a scorpion outrunner.
          i have sent mgm a email on prices for either a program card or usb link cable
          as i cant get my head around there programing system threw the tx
          • Jeepers
            • May 2007
            • 2050
            try contacting Ray Fuller he used to have some of the USB Links, see if he still has any, when I plugged my controller in to the USB, my voltage cutoff was set to "automatic"
            • ozzie-crawl
              • Sep 2008
              • 2943
              thanks jeepers will try ray aswell
              • Team FFRB
                • 328
                Mgm
                MGM USB interface is the way to go.
                You will be amazed at what settings you can change
                Have had no issues so far with any MGM controllers - They are top notch! 100 time better than
                HOT RODS ON WATER
