Doing all the wrong things.
  • Diegoboy
    • Mar 2007
    • 7443
    Sitting here charging a lipo in the house, I find two of them (1-3S maxamp & 1-3S Zippy) below minimum voltage. I didn't want to give up on them, so I charged them as Nicad 9-cells @0.5A (ignoring the balance leads) It brought the lipos above minimum voltage. Then I charged them as normal. Any harm in what I did?
  • m4a1usr
    Fast Electric Addict
    • 2036
    Maybe. Have you attached a balancer to see where each cell ended up? The packs will only be as good as the worse cell.
    John
    Change is the one Constant
    • Diegoboy
      • Mar 2007
      • 7443
      After the 0.5a Nicad charge, I balanced them and charged them normally (as a lipo) everything seems cool with them...
      • Xzessperated
        • Apr 2008
        • 3063
        Danny I rescued a rather expensive 45c Thunder Power pack by charging it as an A123 until the voltage was OK to finish it as a Lipo. I have had at least 8 trips to the lake with it since then. The boat is going faster than ever (because of prop changes) so there appears to be no damage done.
        I am not recommending it, just saying it worked for me.
        • Diegoboy
          • Mar 2007
          • 7443
          Thanks.
          I wish I'd have known this trick sooner, I threw away 2 lipos because of under voltage. I'm glad I gave these 2 a second chance.
          • domwilson
            • 4411
            I've read several posts here where guys have done the same thing with success. I've also read that freezing and thawing them and recharging works. So I've tried it on a dead laptop battery that wouldn't charge. It worked.
            Government Moto:
            • ozzie-crawl
              • Sep 2008
              • 2943
              how do they get below voltage in the first place
              • marko500
                • 862
                I used that trick on a Flightmax pack that dropped to about 2.6v per cell. I used it all last season and it still charges, balances, and runs as good as before. Mine dropped that low after I forgot to unplug it and remove it from the boat when I was done Running. I guess the external BEC drew it down that far.
                • Diegoboy
                  • Mar 2007
                  • 7443
                  Ran it till the LVC kicked in and waiting a few weeks to charge it.
                  • Xzessperated
                    • Apr 2008
                    • 3063
                    I am not going to tell you he said with a red face.
                    OK here is another embarrassing moment. I did not set the cut off.
                    • Diegoboy
                      • Mar 2007
                      • 7443
                      Paddy, I like youe answer better, can I change my answer please??
                      • Xzessperated
                        • Apr 2008
                        • 3063
                        Yes change it.
                        I am not going to tell anyone how many packs I killed this way Danny. Half of them probably could have been saved if I had tried really hard.
                        • ozzie-crawl
                          • Sep 2008
                          • 2943
                          makes me wonder if iam a bit annul about my battries,i cant afford these days to kill one so i dont run mine till lvc.
                          when i set a boat up i do the usall short runs and work my way up but also see how much mah i use. i then set the timer on the tx for how long i can safley run before things get to hot or the lvc kicks in.
                          • Doug Smock
                            • 5359
                            You can't be too anal when caring for your LiPos IMO.
                            MODEL BOAT RACER
                            IMPBA President
                            IMPBA 19887L CD
                            NAMBA 1169
                            • ozzie-crawl
                              • Sep 2008
                              • 2943
                              dont want to pinch dannys thread but for the first time my lipos are going to be unused for a few months,acouple of my chargers have storage capability
                              is this what you guys use,what should the be stored at voltage wise?
