flex vibration
    I run a similar setup and don't have an objectionable vibration - but my stuffing tube runs into the strut nose. Ditch the current funky strut and get a SpeedMaster strut with a sleeve bearing. Use 1/4" OD tubing for the stuffing tube. As suggested, use a short length (3") of the next size larger tubing epoxied through the hull and replace the current tube. Run the tube through the strut, and end it no more than 1/2" behind the coupler. When gluing the short tube into the hull, chuck up a 4"-6" length of 3/16" drill rod in the coupler to obtain perfect alignment between the motor and stuffing tube. This reduces drag and noise. Use plenty of a good lube on the cable. An "S" bend is not necessary at all, I stopped using "S" bends at least 15 years ago.
    If all the pieces are true and not bent, perhaps the vibration is not excessive. Running the motor on the bench is so unlike what happens in the water that it is almost worthless in diagnosing driveline problems. Set the boat in the water, hold on tight and blip the throttle as before. Still have the vibration?
    • Rumdog
      • 6667
      Thanks so much guys. Yes, it is un-supported at the strut end. The strut is the original, it used to be a nitro hull and it used the brass cone behind the flex, in front of the strut. I'll go ahead and order up the speedmaster and bigger O.D. stuffing tube. The vibration right now is VERY excessive!
      • Jeff Wohlt
        • 2740
        Yep...any vibe in that strut nose areas is only going to compound and shake the stuffing tube...eventually leading to possible stuffing tube issues at the hull.
        Jay T has you on the right path. New stuffing tube and in to the strut.
        www.rcraceboat.com
        jwohlt5362@yahoo.com
