Parallel ESC's ?
  • egneg
    • 4759
    Parallel ESC's ?
    Just thinking out loud here ... can two 120 amp ESC's be connected in parallel to make a 240 amp ESC? Has anyone tried it? I did a search but found nothing.
    IMPBA 20481S D-12
  • Diegoboy
    • Mar 2007
    • 7444
    Great question, Parallel (voltage =same / current = doubles) interesting thought. I'm waiting to see if anyone tried it...
      No, it's not that simple. With two hooked up to the same motor, they would fight over which one ran the motor. I suspect they'd last less than a minute and would not run the boat. If you can wire the power boards together with a single control board, then perhaps.
      • m4a1usr
        Fast Electric Addict
        • 2036
        They wouldnt be in sync 100%. Out of phase to some degree. Remember B/L motors are A/C.
        John
        Change is the one Constant
        • graill
          • 407
          Thats a no Chuck. The one thing to keep in mind is the limit of the individual ESC, they might be paralleled but they will still only take their individually rated amperage before blowing.
            • 7512
            For the price of two 120's,,,go buy a 240..............
            • egneg
              • 4759
              OK ... I thought it sounded to easy or it would have been common knowledge by now.
              IMPBA 20481S D-12
              • egneg
                • 4759
                If Turnigy made a 240 amp marine I would as I can get 2 120's for a little over 100 bucks.
                IMPBA 20481S D-12
                • domwilson
                  • 4412
                  No can do. The ESC not only provides voltage/current to the appropriate windings with the appropriate frequency and pulse width, they must also read the back EMF to determine speed and rotation. In addition, they would need to be triggered simultaneously. Plus...depending on the output design, they may not like the "bridging" of circuits and end up with a catastrophic failure of monumental proportions.
                  Government Moto:
                  • SJFE
                    • 4867
                    I remember asking this question over a year or so ago. I was equally bummed. Wouldn't it be sweet.
                    • Jeepers
                      • May 2007
                      • 2050
                      I think you might be right!
