When installing turn fins on a mono hull, should they be perpendicular to the hull? What I mean is perpendicular to the V. I assume the reason is that the outside fin would be out of the water while the inside one is doing the work. Also, is there a general rule on the depth, like 1/4 inch less than the keel at the transom? Thanks
turn fins on a mono
All of my V hulls have no turn fin in the water on plane. Its added drag and does nothing to stabilize the hull while going in a straight line. My rule of thumb is its needed in a turn and nowhere else. Now where to set them depends on how much clearence the hull has and if you are suffering any effects from the transom spinning out during a turn. Its safe to say that each turn fin should be 90 degrees from the angle but alot depends on stability too. This might require a slight modification to that assumption. I like mine mounted as far out as possible but opinions vary so let the commentary decide. Stability is the issue so as speeds increase so does the importance of location.
JohnChange is the one Constant
Here are a couple of photos of a couple of my boatsAttached FilesDon't get me started
