pistix device ?
  • lucozader
    • 144
    pistix device ?
    i have a standard boat tx and rx
    i am using an airplane esc
    what is the behaviour difference of the aircraft esc
    what difference does the pistix device make ?
  • m4a1usr
    Fast Electric Addict
    • 2036
    Andy can answer this definatively but a Pistix allows you to use a A/C speedo, I.E. stick transmiter controlled, when you only have a pistol grip Tx.
    John
    Change is the one Constant
    • Diegoboy
      • Mar 2007
      • 7443
      Most aircraft ESC's are not designed to use a "pistol grip" radio. The device allows the use of a "pistol grip" radio on an airplane ESC.
      It primarily adjusts the throttle signal. 2 stick radios throttle are 50%-50%. where most pistol radio throttles are 70%-30%. therefore the neutral position is not the same.
      • lucozader
        • 144
        i ordered a pistix from ose
        thanks guys
        i'll see how it goes, if i understand correctly it will give me an extra 20% forward speed ?
        • screwball
          • Jul 2009
          • 464
          no basically on a pistol style radio the deutral setting for the throttle is different that the stick type radio that the esc was designed for, so the pistix allows you to use the aircraft esc with a pistol style radio. last night i found that you can use the stock traxxas tq radio that comes with traxxas cars and trucks has a 50/50 setting so i can use it without a pistix, since i accidentally broke my pistix the other day and i do not feel like spending another 25 buck on one i decided to just modify an extra radio that i had lying around and to my surprise i didnt have to do anything to the stock traxxas to make it work. but i painted it white anyway :)
