Astro Flight 207d and FDM SS1 info
  • arrowskartax9
    • 130
    Hello, Does anyone have any technical info for the Astro flight 207d speed contoler?
    And any info for the FDM SS1 cordite engine??
    I have these items in my 31" mono and the engine doesnt seem to rev as hard as i would have hoped.
    I am running twin 7.4 volt 25c 5000mah lipos.
  • sjslhill
    • 1563
    thought
    The 700 motor is for 14.4V, not 7.4
    Info on the 207D, which is not for 7.4 either. You need a 212D or something else.
    Voltage range 7 to 60 Volts
    Turn on Voltage 7 Volts
    BEC Cut off voltage 6 volts
    Number of Nicad or NIMH Cells 6 to 40 Cells
    Continuous Current Rating 60 Amps
    PWM rate 3 KC
    BEC Rating none
    Opto Coupling Yes
    Length 2 inches
    Width 1 inch
    Height 1/4 inch
    Weight 40 grams
    Servo Connector Universal
    Power Cables 13 gage
    Power Connectors Astro
    • arrowskartax9
      • 130
      Hello, thank you for replying. With the 2 lipos linked that brings the voltage up to 14.8 volts.
      Is that the correct way to work it out? And is that ok for this motor and speed controler?
      It came as a 100% rtr from fine design and this is their setup.
      • Steven Vaccaro
        Administrator
        • 8934
        The voltage is good. Depending on the prop used, you should be in the 25-30mph area. The only thing to worry about is that the astro doesnt have a low voltage cut off for the lipo packs.
        Steven Vaccaro
        • sjslhill
          • 1563
          woops
          I missed the twin part....Steven is correct.
          • SJFE
            • 4867
            Hello Mr Hill Nice to see you .
            • sjslhill
              • 1563
              Hey
              How ya been doing?
              • arrowskartax9
                • 130
                Thanks for the info. I am going to use X440 prop.
                Do i need 2 seperate low voltage cut offs or just 1 ?
                Chris.
                • SJFE
                  • 4867
                  Been ok man I hope the battery Biz is still goin ok for ya.
                  • steveo
                    • 1595
                    Chris.
                    a x440 is a little small for a 31" mono, i had the same motor in a 32" mono running a 445/645/448 with no problems try a few cheap cf props
                    • arrowskartax9
                      • 130
                      What is better for this setup for my boat, In series or paralell for the lipos? At the moment they are in paralell.
                      • steveo
                        • 1595
                        if you have 2 7.4 lipos wire them in series to get 14.8 volts
                        series= voltage is additive and amperage remains the same
                        parallel=amperage is additive and voltage stays the same
                        • steveo
                          • 1595
                          if your are in parallel now you have just extended you runtime and current draw, and i am sure its not fast at the moment
                          wire in series and watch out its like night and day for speed, but your runtime will not be as long
                          • arrowskartax9
                            • 130
                            Thanks for the info guys. I have been to my lhs in Melbourne and had a lead made up to run the lipos in series. What prop should i use? Chris at Fine Design sent me x440 3 blade balanced and sharpened for this boat and setup.
                            • steveo
                              • 1595
                              x445/x645/x447
                              do you have a pic of the boat we can see, mostly the transom for the setup of hardware
