Drive Cable Harmonics Remedy
  • detox
    • 2357
    While reading the Zippkits rigger manual I found that an S bend stuffing tube is better than a one bend stuffing tube.
    Why an “S” shape? Tests have proven that a tube with two bends has less drag than a stuffing tube with one. The reason is that two bends support the flex cable better, reducing cable whip, and drag.
    Welcome to Zippkits! : - Cables & Shafts Replacement Parts Hull Accessories Gas Exhaust Propellers Water Cooling Nitro Boat Kits Tug Boat Kits and Accessories Rudders & Struts Gift Certificates Trim Tabs & Turn Fins Drive Dogs & Prop Nuts Radio Accessories Gas Boat Kits Fast Electric Boat Kits Fuel System- Nitro Electric Accessories Apparel Electric Motors Airplane Kits Oil Outboard Accessories Servos Cowlings Nitro Engine Accessories Gas Engine Accessories Glue and Epoxy Decals Batteries and Chargers Custom Radio Box Kits Tools Nitro Exhaust Fuel System- Gasoline Not Eligible for Free Shipping Clearance/ Scratch & Dent Hardware Sets Speed Controls FREE 3D Print Files Boat Stands Collets Boat Stand Kits 3D Printed Parts Free Plans Prop Box Kits zipp, zippkits, boat, rc boat, model boat, model boat kit, propeller, propellor, remote control boat
  • wolf IV
    • 1050
    ive heard this before, but forgot! thanks!!! explains some of the loving sounds coming from my MM stuffing tube ( vibration...)..
    http://www.youtube.com/watch?v=e-npTLBHefY
    • m4a1usr
      Fast Electric Addict
      • 2036
      Why an “S” shape? Tests have proven that a tube with two bends has less drag than a tube with one. The reason is that two bends support the flex cable better, reducing cable whip, and drag.
      http://www.zippkits.com/
      A minimal "S" constructed stuffing tube offers increased support of the flex shaft which does reduce harmonic moment over the given RPM range. However increasing surface area contact does not reduce friction in theory, quite the contrary. But the assumption is that since the movement inside the stuffing tube has increased support, and whip having been minimized or restrained the effect is less friction over the entire RPM range. And that is pretty much fact thru build experience and I assume the recomendation is one of general description. But remember this is only factual when dealing with flex shafts that are very flexible, i.e. they bend easily. On wire drives I doubt the same rules apply to the same degree.
      John
      Change is the one Constant
      • detox
        • 2357
        In theory you can also CRIMP the standerd NON S shaped stuffing tube slightly in different locations using Vise-grip pliers. Adjust pliers so they will crimp exact amount each time without pinching cable. This should help reduce harmonics.
