Different pole motors
  • ReddyWatts
    • 1756
    The Feigao and KB45 rotors have 2 poles and 3 stator coils.
    For a 2 pole motor, the controller will energize a stator coil 3 times in each revolution.
    I guess that means for a 4 pole motor the controller will energize a stator coil 6 times in each revolution.
    If true, it means for a 6 pole motor the controller will energize a stator coil 9 times in each revolution.
    BL sensorless controllers use the feedback pulse from the wire not being used while it is energizing a stator coil to AUTOMATICALLY sync with the rotors of the different pole motors.
    2 pole energizes a stator coil every 120 degrees of rotation.
    4 pole energizes every 60 degrees.
    6 pole energizes every 40 degrees.
    The more poles the motor has gives it more torque for pushing larger hulls, weight and props. While using less amps, since they are more effecient.
    A 4 pole motor is more forgiving than a 2 pole when accidently over propped. The current surges are not as high.
    More poles make the controller work at a higher frequency to get the same rpm as a 2 pole. Not sure how that effects your controller tempurature?
    Does everyone agree with all this? I am still trying to understand it!
    ReddyWatts fleet photo
  • SJFE
    • 4867
    Sounds pefectly logical to me.
    • NorthernBoater
      • 869
      How many poles do the Neu and Lehner motors have.
      • Jeepers
        • May 2007
        • 2050
        NEUs are 4 pole motors.
        I think lehners are 2 pole also, ( I think)
        • ReddyWatts
          • 1756
          Lehner, Feigao, Hacker, Nemesis, KB45 have 2 poles.
          Neu, Plett have 4 poles.
          Mega has 6 poles.
          I guess the KB45 is a Lehner 2250 clone.
          • seabassturd
            • Jul 2007
            • 52
            and the shark motors by mhz have 8 poles i believe
            • steveo
              • 1595
              i think the sv27 motor is 6 pole
              • SJFE
                • 4867
                I can only hope :)
                • ReddyWatts
                  • 1756
                  Look at the specs.
                  Lehner 2250 - 10 turn - 2 pole
                  size - 44mm/81mm
                  Power(Watts)----/---Amps ---/KV / Weight
                  3000 Watts / 50-100 Amps / 1184 / 560g
                  KB45 - 10 turn - 2 pole
                  size - 45mm/77mm
                  Power(Watts)/---Amps --/KV / Weight
                  3000 Watts / ?? amps / 1200 / 555g
                  Maybe it will perform close.
