Aluminum rails
  • RIPFENCE
    • Sep 2009
    • 1577
    Aluminum rails
    HI ALL,
    DO ANY OF YOU USE ALUMINUM RAILS TO MOUNT YOUR MOTORS/RADIO BOXES INSTEAD OF WOOD? I HAVE NOT SEEN ANY PREMADE TO ORDER...I WAS THINKING ABOUT BUYING SOME ALUMINUM CHANNEL TO MAKE MY OWN.. I JUST THINK IT WOULD LOOK NEATER AND BE STRONGER ALSO MATCH THE NICE RAIL STYLE MOTOR MOUNTS I HAVE SEEN..THE ONLY PROBLEM WOULD BE SECURING IT TO THE HULL WITHOUT MAKING A GUMPED UP MESS. MHZ SELLS A SET OF PLASTIC LOOKING RAILS PRE CUT AT $65.00 WAY TOO MUCH..ANY THOUGHTS?
    "FE" STANDS FOR FRUSTRATING EXPLOSIONS
  • Chilli
    • 3204
    If you use it, be very careful. As you probably already know, aluminum is an extremely conductive material.
    Mike Chirillo
    www.capitolrcmodelboats.com
    • RIPFENCE
      • Sep 2009
      • 1577
      i could not imagine the results of a connector coming loose and laying on a rail...that would be a bad day..maybe its not such a great idea..if i was a more experienced boater maybe it would be worth it..until i am totally confident in my setups i guess i will play it on the safe side..thanks for the input nautiboyz
      • FloatDaBoat
        Bare Bones Fabricator
        • Sep 2009
        • 421
        RIPFENCE:
        Here's a photo of a Novak 7.5 HV Pro motor installed using an aluminum mount in my custom built 30" cat. I originally had two brushed motors connected end-to-end utilizing this mount; that didn't quite pan out as I'd hoped, so instaed of making a new mount, I just used what I already had.
        • sailr
          • Nov 2007
          • 7128
          A member here at OSE makes beautiful aluminum mounts. They are wonderful. Also some made by Williams. Sorry, don't have the links just now.
          Mini Cat Racing USA
          www.minicatracingusa.com
          • RIPFENCE
            • Sep 2009
            • 1577
            I purchased a mount from south river rc..they have some real nice ones for reasonable prices..maybe i will buy some aluminum channel and make some rails to match..thanks for the pics and info
