i was hoping that someone would be able to give me some advice on the most inexspensive way to build a 60+ mph boat. I currently have a rigger with a fiego xl running on 4s but i want to make a faster one for the least amount of money i can. I was thinking either a nother rigger or a catameran. any advice will be greatly appreciated.
60+ mph
Buy as much as you can used from the swap shop. I have an H&M XS2 that came with the hardware/servo/wire drive installed - $100, Turnigy100 amp esc water cooling added - $30, Feigao 8XL w/ cooling jacket - $55, and for new stuff $40 - $45 for prop, water tubing, thrust bearing, motor mount, and connectors. Batteries and RX not included because they can be used in more than 1 boat. Total cost $230 and it does over 60 MPH.
Edit: it is the boat in my avatar,
Edit # 2: I didn't mean to confuse anyone but the boat is not for sale - I just used it as an example.Last edited by egneg; 12-02-2009, 02:55 PM.IMPBA 20481S D-12
What rigger do you have, picks are very cool hereOriginally posted by bea5017 View Posti was hoping that someone would be able to give me some advice on the most inexspensive way to build a 60+ mph boat. I currently have a rigger with a fiego xl running on 4s but i want to make a faster one for the least amount of money i can. I was thinking either a nother rigger or a catameran. any advice will be greatly appreciated.
How fast does it go at present ?
Which XL motor do you have ?
What is your prop ?
What is your ESC ?
What pack(s) are you running ??
Show us your existing hull and answer all of the above questions and I am sure that we can help you hit 60+
I have a hand built wooden rigger that runs a Turnigy 6XL with a Mystery 200A (uncooled) from a Rhino 4S 4900 to a worked 642 prop.
This thing is flirting with and blowing kisses at 70mph.
an 8XL on 4s2p and a Hydra 240 will get your Cat there... I have seen it, right Tony?!
Tony?, Tony, you there? Damn, he's not answering... but he did it. I believe it was 61 or 62mph:::::::::::::::. It's NEVER fast enough! .:::::::::::::::
Jan, that is just teasing us all.Originally posted by Ub Hauled View Postan 8XL on 4s2p and a Hydra 240 will get your Cat there... I have seen it, right Tony?!
What hull and what prop ??
Tony is a wicked builder and driver too, so that will make a difference.See it....find the photos.....sketch it it....build it........with wood
My Drifter S with an 8XL on 4S2P with an X642 did a smidge over 60. I'm soon to offer it up for sale
on the cheap. Get a Seaking 180 for $115; some Turnigy batt's for @ $130 for 2 & you'll be there. PM me if interested.
here's a pix.Attached Files2008 NAMBA P-Mono & P-Offshore Nat'l 2-Lap Record Holder; '15 P-Cat, P-Ltd Cat 2-Lap
