Mystery Brushless ESC
  • BakedMopar
    No Mo Slipah
    • Sep 2009
    • 1743
    After accuiring a Mystery 80A speed controller from DiegoBoy I have endlessly searched many forums for programming this thing. After finding a whole bunch of different "Programming" procedures heres the one that works. Found right here on OSE.
    Originally posted by ED66677 View Post
    here's what you can program and the way to do it, throttle stick at full then turn on ESC, you'll hear that little music and then some short (.) and long (-) beep as following:
    1) - - - Brake On
    2) -- -- -- Brake Off
    3).- .- .- NiCd/NiMh
    4).-- .-- .-- LiPo
    5)..- ..- ..- Soft Startup
    6)..-- ..-- ..-- Hard Startup
    7)...- ...- ...- Soft Timing
    8)...-- ...-- ...-- Hard Timing
    9).... .... .... Reset to factory settings
    You can change multiple settings at a time. Start at full throttle and after the little music notes it will sound those codes for that parameter. Once you hear the code for the parameter that you want to change go full brake quickly then back to full throttle. When at full brake you should've hear a single beep meaning you set that parameter, then it will start from the begining and you do the same for any other parameter you want to change. when done return throttle to neautral postion and you will hear the startup tone followed by one or two beeps depending on which brake setting you chose.
    NOTE: I use a Airtronics FM 75mhz radio and I need to use a PiStix for it to work.
    George
  • exotica
    • 159
    ...ived ordered the 200amp version of this which im dying to try out in my MOPAR cat! Cant wait to see what it can do. Im hoping for 50mph.
    • BakedMopar
      No Mo Slipah
      • Sep 2009
      • 1743
      Well mines died on Sunday. I don't think these are a bad deal though. I wasgoing to order a couple of those 200a and try them out again. I have mixed feelings about them. They run great when it did run but that was only two 3-4 minute runs. It never got hot, just stopped working then they seem to short out (made the batteries and connectors hot in a second). They are very cheap though.
      • screwball
        • Jul 2009
        • 464
        ive been running the 40A`s in my small boats for quite some time with great results
        • exotica
          • 159
          ...for about $40 you would hope for at least 40 runs. Ide be happy with that. Im wondering just how hard you can push these???? Im going to install this in my cat and run an Octura X445 prop, 9XL with 6s. Ill run it only for about a minute to see just how fast she will go.
          • screwball
            • Jul 2009
            • 464
            the 40A??!?!?!?!?!?!?!
            • FE Wannabe
              • Jul 2007
              • 654
              Has anyone tried one of the Mystery 200 Amp ESCs with a JR FM 75Mhz radio? I was thinking about getting one of these ESCs but I want to know if it will work without a PiStix adapter.
              Thanks,
              Brad
              • BakedMopar
                No Mo Slipah
                • Sep 2009
                • 1743
                I know I couldn't get mines to go without one. Don't know about your radio/esc combo though.
