S K Daddle 2
  • blizard05
    • 585
    S K Daddle 2
    What would be a good power option ? Looking for 25-30 mph,with out braking the bank. Larry
    America home of the free, thanks to the brave [/url]
    A 27" mono would work great with an SV or BJ motor/ESC on 4S. Since this boat runs a fully submerged drive you will be better served with a lower Kv and larger prop than what you'd be able to run with a UL-1 setup.
    I suppose you could also run a 10L or 12L Feiago on 2S, but you'll have longer run times with the 4S setups. Lower amp draw for the same power, everything cooler and longer running.
    • blizard05
      • 585
      Would a feigao 540 do the job, if so what esc would work with it ? I'm new to FE, have ben doing gas for 15 yrs. Larry
      • Diegoboy
        • Mar 2007
        • 7444
        The 10L and/or 12L are both varieties of a Feigao 540
        • blizard05
          • 585
          Can I run brushles on NICD packs?I have lots of 7.2v pack, Should I use NiMH,or LiPo ? Like I said I'm new to FE. I'm in the dark when it cones to FE,have to take a class on FE 101. Larry
            • 7512
            A battery is a battery. the motor doesn't care where it gets its power from. You will need a brushless speed controller though.
            LiPos save weight and will give you considerably more speed than a similar voltage NiCd.
            • blizard05
              • 585
              Thanks,I checked out the "for sale,wanted"posts, but I don't know what I'm looking for. Built some Slow electrics, Mid West lobster, the ORCA,and SS MINNOW, but FE( duh) Larry
