P-Spec Motors
  • Hydromaniac
    • Oct 2007
    • 955
    #76
    Originally posted by BILL OXIDEAN View Post
    Steve, that is SO true!!! Any half technical sanction would laugh all night at the idea of a sanction "speking" motors of different wind, length, and magnet constructions
    How are you gonna spec a 2-pole motor with a 6? LoL..
    A spec motor like a ROAR stock or 19-turn have all the same length, diameter, magnet size, and wind. Yes, there are many choices from different mfgrs, but they all fall under the same strict guidelines
    THERES NO WAY MOTORS OF DIFFERENT WINDS ARE SPEC PERIOD!!!!!
    Spec stuff is great for club races, but the nats need to showcase all of NAMBA's wonderful sanctioned classes.
    LSH, LSO are already a staple in our programs, but as much as I love the spec classes and have done well with them, I think that 5 exibition classes crammed into an already hectic race schedule is not an affective use of time.
    IMO These are the classes with the largest turnout of racers in the past and are the most popular as well as what is mostly raced in this area so, as per the rules, emphasis should be placed in those areas correct? This is only one power group and there will be other Classes as well.
    www.rockymountainthunderboats.org
    • Hydromaniac
      • Oct 2007
      • 955
      #77
      This is not a Nats thread.
      Not sure how but this thread is heading towards a discussion of the 2010 FE Nationals and that is off topic of the original thread. We have a plan for the Nationals and the classes that will be ran. So there will be information forthcoming as things get finalized, This information will be presented in 2010 FE Nationals driven threads, discussion and corespondence.
      • Littlescreamers
        • Jan 2009
        • 85
        #78
        Thanks you for clearing this up :D I was worried there for a sec. I want to bring new powerful and inexpensive water jacketed outrunners to you all for sport and racing.
        Thanks again.
        Scott
        • Darin Jordan
          • 9446
          #79
          This pretty much what I'm trying to get at here... Basic parameters are currently:
          Can Length: 50-56mm
          Can Diameter: 36mm
          Weight: Maximum 8oz
          KV: 1500-2050KV
          Power: 600W continuous
          Amps: 50A continuous
          Poles: 6
          That's still a LOT of range, and those are just rough numbers for power... but that's what we currently have spec'd, and depending on the application, they seem to play together OK...
          In my opinion, the UL-1 motor is still an outlier, but we've seen that, while it has more KV, it can't swing as big a prop as the others, so things balance out depending on the package you put together (hull and power system)...
          I think when you start trying to stuff 2-poles, or Outrunners into the mix, you no longer have a "spec" class... you have P-Lite, and that's not what this was suppose to be about...
          Darin E. Jordan - Renton, WA
          • Grimracer
            • 660
            #80
            • Littlescreamers
              • Jan 2009
              • 85
              #81
              Originally posted by sailr View Post
              The motors will only produce the watts depending on the amps drawn and the volts used! So if you used a scorpion or an ammo, at 14.8V and it drew 50A, the watts are EXACTLY the same as the SV and the UL1, 740.
              The watt ratings you see are only the MAX they can produce, not what they actually put out. What they put our depends on the volts and amps.
              This is a very true statement!
              Scott
              • properchopper
                rcgoatbuild@snotmail.com
                • 7708
                #82
                A note on trusting "specs" : There are sooo many ways "specs" can be arrived at. A good example of how specs can be misleading is in the stereo industry. One amplifier can be rated at 300 watts. This measurement is done at 1K Hz with 5%
                THD. Another is rated at 50 watts, but at 20-20K Hz with less than .05 THD. The second rating is known as RMS (root mean square)watts. In this case the 50 watt amp is a better performing unit. This is still common, especially with cheap home or car stereos. Before trusting motor power ratings such as "continuous" or "max", the testing methods, and of critical importance the definition(s) of what constitutes "continuous" and "max" and many other parameters need to be known to make sure that they are the same. I doubt that they are.
                Realistically, the # of poles, weight, KV, and physical dimensions can provide some realistically relevent ways to determine parity. The power ratings, which are really the bottom-line comparator, may not accurately reflect such parity.
                Please understand that I'm all for spec racing (and the rules for fairness). I applaud all the efforts and concern to make this a bigger part of the sport and personally am gratefull to everyone that strives to push it foward.
                • Ub Hauled
                  • Aug 2007
                  • 3051
                  #83
                  Can I have an "amen" for Mr. T-Bone?!
                  • properchopper
                    • 7708
                    #84
                    Thanks Bro, I knew you, as an Audio Engineer, would understand !!
                    • Doug Smock
                      • 5359
                      #85
                      Originally posted by Grimracer View Post
                      You're in good company.
                      Doug
                      PS Steven, better pop some more.
                      MODEL BOAT RACER
                      IMPBA President
                      IMPBA 19887L CD
                      NAMBA 1169
                      • Ub Hauled
                        • Aug 2007
                        • 3051
                        #86
                        Doug
                        Doug, don't hog the popcorn, pass it over dude!
                        • raptor347
                          • Jul 2007
                          • 1177
                          #87
                          Will,
                          Remember that LSH and LSO haven't officially been run as they appear in the rule book since 2006. The 2007 nats ran them as unoffical classes because they ran with LiPos before they were officialy legal. The 2008 nats ran with P-spec power rather than the legal brushed 700's. 2009 again ran P-spec power and LSO magicly became a 4 minute race instead of 10 laps. So in essence, those classes haven't actually been run for the last 3 seasons. We should stop using the class names for something they aren't.
                          Plus, there were 7 exhibition classes at the nats in 2009, the 4 spec classes plus production, ultimate offshore and sprint. Backing it down to 5 will be an improvement.
                          Brian "Snowman" Buaas
                          Team Castle Creations
                          NAMBA FE Chairman
                          • Ctonez
                            • Jul 2007
                            • 410
                            #88
                            Honestly, I was originally surprised we allowed the UL-1 motors in the same class as the BJ and SV27 motors. In certain hulls, however, I have seen the SV motor be right on par with the UL-1 motor when propped right for the application.
                            I'm sure the thought of Brian re-outfitting his fleet is alarming, but that simply means that we should test and reconsider before including it with our other spec motors.
                            Was it a hasty decision? maybe, but we are at club level and not bound by this vote.
                            More research is necessary for sure, thanks for your work so far Darin.
                            I run SV motors, because I have so many and don't NEED any replacements yet, but when I do, as Greg mentioned, I won't be gettin an SV motor. I'll get whatever gets me the most bang for buck, which hopefully will be a tough decision due to parity...so I would be disappointed if the 1800kv Ammo whomps butt, but would probably get one if we allow it, so I get the point.
                            I am, however, completely with Greg on the point that this should not be continued online. Call me anytime, or let's dicuss it via club email.
                            • Ctonez
                              • Jul 2007
                              • 410
                              #89
                              Can Length: 50-56mm
                              Can Diameter: 36mm
                              Weight: Maximum 8oz
                              KV: 1500-2050KV
                              Poles: 6
                              So to appease those that want more selection, what, if any other motors fall into this range? ...I guess that's the big Q.
                              Doesn't price deserve to be a parameter since it helps define the spec further?
                              Another concern is supply longevity. We've seen periods of more demand than supply in the past, is there anything that can be done to assure the approved motors are around and plentiful for awhile? Maybe the popcorn eaters can answer that one...
                              • raptor347
                                • Jul 2007
                                • 1177
                                #90
                                Cory,
                                Don't worry about the motors. I've talked to the AC guys about supply (I'm pretty sure Darin has talked to the ProBoat guys). The run on motors was a suprise. They stocked enough to support the product they were supplied in, not expecting them to be used in most of the race boats built that summer. They are aware of the demand now, with no plan to stop building them in the near future.
                                I have an interesting question: Why is the cost of the motor so important but nobody cares if you use a $250+ ESC? For that matter, how about battery price (40C thunder power packs for spec )?
                                Last season I ran UL-1 motors in rigger, tunnel, sport hydro, BJ26 in the mono. UL-1 escs with an added capacitor. $86 4S 4100 mah 25C Neu cells. No failures and better than average performance. Maybe the motor is the least of the concerns for the spec class.
                                NAMBA FE Chairman
