P-Spec Motors
  • Norman2
    • Sep 2008
    • 354
    P-Spec Motors
    That's fine... but the "choice" of motors need to be simliar in specs... 600W vs. 1400W is hardly apples to apples...
    Darin, Your club's rules are right on. We had a meeting several in our local club
    to discuss the same thing and decided only SV27, BL26, and UL-1 motors were
    allowed and only 4S lipos. The only change we made was to include hull that
    are 32". A few members had HOTR mono and cat hulls and the initial rule was
    26-30". Your new rules are fair and should be adopted by NAMBA.
    Norman2
    34" Ekos Cat UL-1 Powered
    • Darin Jordan
      • 9446
      Originally posted by Greg Schweers View Post
      Darin, at yesterday's meeting you said the Amo wouldn't be able to compete against the Black Jack and UL1 motors because it was only a 2 pole motor and wouldn't have enough torque. Basically, we only have a 2 motor choice right now because no one is going to purposely buy an SV motor. Like I said, I don't like supporting one company - what happens when you can't buy a UL motor, you'll be stuck buying a motor you don't want. I just checked Tower and the Amo 1800 is only $49.99. The reason we voted it in is to see how well it will compete - now you're trying to ban it before we ever get a chance to test it. The Amo might not even work - this could be a moot issue.
      Greg, I changed my mind after seeing the specs.... and realizing that the motor Jim had been running, and the one I thought it was, weren't the same motors... There is also an AMMO 36-50-1500KV... Which is 770W... that's what I though were were talking about here...
      Let me put it this way... as soon as Brian found out the AMMO would be legal, he was perparred to order them for ALL his spec boats...
      I'm not trying to do anything... Just putting the info out there.
      The P-Spec classes are finished, however, if this type of motor is allowed. Where will it end?
      Darin E. Jordan - Renton, WA
      • Darin Jordan
        • 9446
        What everyone apparently has chosen to overlook is that for a number of years we had two-motor LSH and LSO classes and they worked rather well. The choices? The SS-1 and the 700 SC. We did have a larger pool of 700 motors to choose from, but all serious racers used one of the above two motors - the most expensive two.
        All the hand-wringing aside, these are LIMITED classes. Open the door to a large number of motors and the result will be just as before - all serious racers using the one motor which provides the greatest performance, regardless of the cost. Listen folks, history is speaking to us.
        Thanks Jay... I completely agree....
        • Darin Jordan
          • 9446
          What is driving the need for new choices in the class?
          People don't want to be tied to a specific manufacturer... Some want to buy performance they aren't able to tune for... Others just like to experiement... Others want "cheaper" alternatives... Some just hate the RTR industry and cringe when it comes to supporting it.... Some just can't stand not having the latest, greatest "next best thing".... Some worry about supply...
          • T.S.Davis
            • 6266
            haha Steve, the obvious question. I asked that somewhere once and the red board blew up. It's coincedence but it still made me chuckle.
            Weren't all of the 700's Mabuchi motors I think. Wasn't that relying on a single manufacturer? Those classes were a huge success. Guys, your thinking too hard on this. The 700 motor classes only lasted a few years before something better came along. We were all running Graupner 700bb 8.4's and 700 Neo 9.6 motors when the SS1 hit the market.
            The exact same thing is going ot happen again. New motors are going to come out. I believe that's Darrin's motivation. He's trying to collect data so that we know the parrameters. Then as new players come along we'll have some idea how or even if they fit in with what we already know.
            Noisy person
            • Darin Jordan
              • 9446
              Originally posted by Scott T View Post
              ...you'd be better off nominating or testing a 36-50-1500? Similar weight, power and revs to the Proboat motor (obviously different # of poles).
              Unfortunately it's more expensive than the 36-56-1800, but it seems to tick the right boxes and offers an alternative.
              The 36-50-1500 is also only rated at 35A/770W constant 80A/1775W Surge... so it's more inline with the other P-Spec motors... It's weight/mass is also more inline, at 8.6oz/243g... I'm not sure what the surge watts are on our Spec motors now... I'm trying to get that info, as well as the base power for the two Aquacraft motors...
              This is the motor I thought we were discussing in the meeting...
              I actually suspect we'll find that the UL1 motor is rated a bit higher than the other three, but we'll have to see. It's mass is only 212g... and it's max surge current is 80A, so it's still inline with the others... overall power wise.
              • Darin Jordan
                • 9446
                As Terry eluded to, here is my motivation:
                1) Motor Specifications
                The intent of the P-Spec Power Specifications is to define a motor package to be used in P-Spec and Limited class racing. These rules are intended to either supersede, or be in addition to, any rules pertaining to motors for a given class, as specified within the rules for that class.
                Motors in these specifications shall be based on readily available parts from past, current, and/or future Ready-to-Run offerings by various manufactures. Only motors on the approved motor list shall be allowed. Other motors that meet similar specifications to the motors on the Approved Motor list may be considered at the discretion of the Club. These motors shall be run initially on a trial basis for ½ points until the Club decides to approve and add them to the list, or to reject them.
                Motors are intended to be used as they are supplied. Therefore, no alterations or modifications are allowed, unless specifically stated in these rules. Motor shall be directly connected to the output drive shaft, no gear/belt over/under drives will be allowed.
                We have to know the specifications, before we can know if the motors should be allowed...
                So to further address Greg's concern, NOTHING should be approved to be added to the list without having all the specifications available to the best of our ability. Just going off of "so-and-so ran it and it looked fine" isn't really good enough... even if I'm saying it...
                • properchopper
                  rcgoatbuild@snotmail.com
                  • 7708
                  Originally posted by ozzie-crawl View Post
                  okay iam just missing the big picture i guess as i dont race and not sure on your spec classes.
                  i assumed (and you know the saying "assumption is the mother of all") that they are restricted to a 4s setup
                  if all motors are capable of 50 amps constant draw and everyone is limited to 4s then to me none of them can produce more than around 740 watts (nominal volts) this is once again assuming the motor specs given by manufacturers are correct
                  if a motor has a 50 amp constant capability i dont see if it matters that it could produce 1850 watts at 10s if its restricted to 4s and can still only produce 50 amps constantly
                  WHAT AM I MISSING
                  Thanks ! That was the point I was trying to present. Power IN has to equal power OUT minus efficiency losses. I'll just back off and listen. [Besides, even if I competed with a supposed "better spec'd" motor, my driving inexperience would handicap my chances.] I'm all for spec classes for obvious reasons- I just wanted to contribute to the fray by pointing out that motor specs be better understood, plus I have some water time with the Scorpion and wanted to present my experiences to see if they would help.
                  • sailr
                    • Nov 2007
                    • 7128
                    Exactly! You are right on the money. For example, the UL and SV motors are 600 watts? At 50A that means they can only run 12V? (watts/A = V) BUT they are designed for 14.8V? On the other hand, the higher watt motors, at 50A will take higher volts? Something doesn't add up here.
                    The motors will only produce the watts depending on the amps drawn and the volts used! So if you used a scorpion or an ammo, at 14.8V and it drew 50A, the watts are EXACTLY the same as the SV and the UL1, 740.
                    The watt ratings you see are only the MAX they can produce, not what they actually put out. What they put our depends on the volts and amps.
                    WHAT AM I MISSING
                    Mini Cat Racing USA
                    www.minicatracingusa.com
                    • sailr
                      • Nov 2007
                      • 7128
                      This discussion reminds me of the early days of slot car racing. In the beginning, there were only a couple of choices of motors, so everyone was pretty evenly matched. But as time went on there were more and more and more motors available. It became a stupid game...whoever could afford the latest and greatest motor...sometimes buying a new one every week.
                      IMHO, the SPEC classes should be left alone! They were designed to give everyone a fairly level playing field by limiting to the SV, Proboat, and UL motor. I would really hate to see it turn into the "motor of the week" syndrome. It would cause confusion. The SPEC classes were set up to encourage more participation as the costs are low and the equipment reliable.
                      It seems like every time a good thing comes along, somebody wants to start screwing with it. Again, IMHO....I think the SPECS should be left alone.
                      Mini Cat Racing USA
                      • Darin Jordan
                        • 9446
                        ... and EFFICIENCY....
                        • sailr
                          • Nov 2007
                          • 7128
                          Yep, and efficiency.
                          Mini Cat Racing USA
                          • Hydromaniac
                            • Oct 2007
                            • 955
                            IMO I am all for some new motor options, I am not looking for increased performance or "EDGE" I race seriously and run several spec class boats, This results in the use of several motors through a race season. In the past race seasons since the allowance of the current motors the manufacturers have been unable or unwilling to keep up with the demand for them. This has resulted in short supply of the allowed motors. I don't like racing with weak, worn motors or having to bounce motors from hull to hull in order to compete. If other optons were made to us this may lessen the drain from the supply available. With another option or two there may always be an ample supply of motors and I prefer that over the past shortages we've had.
                            www.rockymountainthunderboats.org
                            • Doug Smock
                              • 5359
                              MODEL BOAT RACER
                              IMPBA President
                              IMPBA 19887L CD
                              NAMBA 1169
                              • Darin Jordan
                                • 9446
                                Originally posted by D.Smock View Post
                                CHICKEN!!
