Prop for Titan 29
    • 9481
    Prop for Titan 29
    Ok, I got my Titan 29 together with a Medusa 3670 2300kv
    I'm going to run in a stock class with a SV27 motor, possibly with a 45mm prop..
    but with the Medusa on 4s what would be a great prop to use?
    I tried a S220 and it looked to be about 45mph? I left my gps at home
    any help would be great!
  • Jeepers
    • May 2007
    • 2050
    Brushless, a few good props to try would be x440 x640 x442 x642. are you coming down to race with us in Pueblo? By the way sweet UL1 in you avatar! I remember you telling me you did it as "Caterpillar"
      • 9481
      yep, I am going to try and make it down there next season!
        • 9481
        Well, I ran my Titan with a 45mm prop and jacked up the shaft...
        The coupler came loose just enough to slip and melted the solder on the end of the shaft and it came unravled
        • properchopper
          rcgoatbuild@snotmail.com
          • 7708
          Ran the Titan 29/SV27 combo today with a Grim 42/55 mildly detounged & cupped.
          Liked it a lot; temps were fine. More prop testing to come. What've you found ? I'm not sure the temps in a 4 min LSO race using a 445 would hold - or the 4S1P batt would like it. Get the shaft replaced & report !
          • highndry
            • 685
            sdgf
            Proper is on the money. Additionally, Titan needs tabs with ~ 1 or 2 degrees neg trim, otherwise they are squirrely, loose & uncontrollable . At least with the following set-up, they compete favorably in our club. Ul-1 power and 440 for offshore.
            Boats don't win races, drivers do.
            • Jeepers
              • May 2007
              • 2050
              were you using the Medusa or the SV27 I thought you said you were using the Medusa motor?
                • 9481
                I have yet to run the SV power, I ate a motor (SV) in my Revo that I tried one in...
                I ate the shaft with the Medusa, and not sure what I need to replace it?
                  • 9481
                  Thanks!
                  I've not ran my Titan again, cold temps and no new shaft yet and I have no Idea what I need to replace it with...
                  I just got back from a run with my Revo using a Medusa 3680 1600kv and those motors are nice..
                  • properchopper
                    • 7708
                    Make sure you're using a .150 ! A .187 wouldn't be bad either, especially with the Medoozie. I remember a few years ago I was up North with Randy & Dan Chase doing an unofficial dual-stopwatch 2-Lap at Kaiser Cove. I had a 9XL in the Titan with a .130 & was setting a killer time, then right before the finish line - Spladoinge !! Pretzled the shaft
                    [BTW I just screwed up my (unsoldered end) .150 trying to insert it into the collet, then screwed up the collett Live & Learn !
                      • 9481
                      Thank you and it helps to look up the add of the boat I bought!
                      got it all cleaned up and looks much better now
                      it's got a .187
                      http://forums.offshoreelectrics.com/...light=titan+29
                      • properchopper
                        • 7708
                        Just for grins here's a vid from a few years ago with a fresh 9XL on 4S2p with an
                        X442. Boat wasn't dialed in yet [obviously] !
                        • Jeepers
                          • May 2007
                          • 2050
                          replace it with a Hughey .187 assembled flex shaft, available on this site under drive hardware....... darn Steve is out of stock.
                            • 9481
                            son of a
                            • Jeepers
                              • May 2007
                              • 2050
                              son of a
                              LOL!
