After Run Oil
  • traxxman03
    • Jul 2007
    • 4
    After Run Oil
    well, i'm new into nitro boating and i came from nitro trucks. my first boat is a pro boat, the miss. budweiser hydro. What can i use for after run in the engine? with my cars I just used some WD40, can i use this? Or what can i use? thank you.
  • SJFE
    • 4867
    I allways used the after run oil from the LHS. I think wd40 may not be all that good for nitro motors.
    • traxxman03
      • Jul 2007
      • 4
      ok, i'll try the oil at the lhs, thanks:)
      • SJFE
        • 4867
        Any time. I maybe mistaken but I think wd40 is not good for seals orings or gaskets...It's been a verry long time since I have run nitro.
        • dirtysouth31
          • 546
          actually wd40 is good to flush out the oils and water after you are fin ished running..just spray in the carb as you pull on pull start or on the belt with the glow plug out..than spray some in the cooling lines so it will coat the head bolts and spray ubtil it comes out the rudder..than put in automatic transmission fluid or hydraulic fluid and repeat the pulling or belt start to move it around and than your good to go..i still run my nitro 45 outrigger.im a member of a nitro club and a scale electric club also..
          • SJFE
            • 4867
            THAAAAAAAAAATSSSSS it...lol Tranny fluid..I always thought thats what the LHS sold in those little bottles. U DA Man :D
            • traxxman03
              • Jul 2007
              • 4
              ok, I always used WD40 in my trucks but i knew boats were alot different. so after the Wd40 I put tranny fluid in it? Is that just for extra lube? well anyways thanks alot!
              • Gilbequick
                • 140
                Over time wd40 will break down the rubber seals in the motors. Use the ARO!
                • Mich. Maniac
                  • 1456
                  I was always told3in1 oil Ive used it and works great. smokes on startup but burns off clean and seems to work. cheap and easily abailable
                  • Diegoboy
                    • Mar 2007
                    • 7443
                    I don't run gas or nitro, so I can't advise on it. But I have been to Dirtys club races, and all the members seem to do it the way he describes, including the club pres. All those people can't possibly be wrong can they??
                    Although I do prefer 3in1 over Wd40 as a general purpose lube.
                    • Jeepers
                      • May 2007
                      • 2050
                      wow nitro I forget what they sound like. I never even started or pulled on the pull start in my miss vegas boat just pulled the motor stuck a piece of tape over the carb and stuffed it in the closet.
                      • traxxman03
                        • Jul 2007
                        • 4
                        well thanks for the help everybody
