brushless motor rpm's
  • daniellewis
    • Apr 2009
    • 9
    just a quick one
    if any one can help us out
    if running a 4s lipo is there a limit of rpm/volt in which u should run
    or does it depend on the prop and the amps which it will draw
    the boat in which it is going into
    is a df vortex i think it 21 inches long
    etti 150a esc
    x637 prop
    4s 5000mah batt
    any info on what motor should i purchase
    as i an only new at electrics and have no idea as yet slowly learning
  • Rumdog
    • 6667
    I used to have that exact same boat and setup. On 4s you'll want around 2200 kv. A feigao 540L is a great size motor for this setup. A ul-1 motor would also be a good choice as well as the AMMO 2300.
    • daniellewis
      • Apr 2009
      • 9
      is there any difference running an xl motor at 2200rpm/volt
      running the same prop
      will it lower the amp draw ?
      or do u need to run a bigger prop to keep the rpm's in check
      as the motor will be able to spin the prop easier
      there is the feiago 540l professional motor which i think has an rpm of 2150/v is this suitable
      any info
