Hello All,
disclaimer- I am a boat noob- be gentle lol
The matter at hand- I just picked up a boat for free from a family member, its a miss bud hydro- ABS hull, dual mod 540 motors, and some top of the line 1200mah nicad batterys(for super speed[
]) non sharpened aluminum turn fin, plastic stock prop, plastic non sharpened rudder.
After stripping down the boat yanking the old toasted batteries, the esc which was cudely made from switches and a servo.. I checked operation of the two motors. to my surprise they ran, not only ran but ran well... To get the boat runnable I tossed in a spare Modded mamba max from one of my cars, set it to run brushed mode and cutoff for 4s lipo. got all that installed, running 2x 2s 4100mah 28c SMC batteries. now off to the pond.
At the pond I found out that this thing does indeed float. yay! first instinct? yank the trigger, boat sounded like a banshee and started slowly across the lake motor were revving wayy high. was setting steering trim, then was goosing the throttle trying to get the prop to dig in.. after some different methods of applying power- the prop finally dug in and the boat got moving at a good click... But whenever I try and lean into the throttle the prop is spinning and the boat isn't accelerating- Cavitation I beleive?
How can i alleviate this?
Weight bias?
prop
lay off the trigger?
Another lesson learned- rc car drivers suck at driving boats...going slower doesnt make it turn any better...lol.
Thanks for bearing through my boat newbishness.
-Ben
Did some measurements- found out that the prop is somewhere between 33- 35mm (just from scaling from my picture)
if that helps..
Later in the day I killed the dual brushed motors and installed a system from one of my cars.
Aveox 36-15, and a setup the mamba max for brushless.
Went out and bought some 1/8in brass tubing and made a water pickup, motor cooling coil and a heat transfer tube setup to cool the Mamba max's heatsink
With the brushless system and water cooling I could barely get the boat to plane. had to literally had to pin the throttle with the prop cavitating and just wait for the boat to get to a speed where it would hook.
I think i might need a bigger prop?
Thanks for help in advanced.
-Ben
]) non sharpened aluminum turn fin, plastic stock prop, plastic non sharpened rudder.After stripping down the boat yanking the old toasted batteries, the esc which was cudely made from switches and a servo.. I checked operation of the two motors. to my surprise they ran, not only ran but ran well... To get the boat runnable I tossed in a spare Modded mamba max from one of my cars, set it to run brushed mode and cutoff for 4s lipo. got all that installed, running 2x 2s 4100mah 28c SMC batteries. now off to the pond.
Weight bias?
prop
-Ben
if that helps..
-Ben
