deans connectors
  • Mich. Maniac
    • 1456
    deans connectors
    Hey I just noticed that with deans you can solder pos neg however you want as long as they are all the same. I recently got some batts with deans on them allready and they are opposite mine. does everyone go through this or is there a standard as to flat=pos or vertical=neg? I would suppose tamiya connectors would be the same way but i have never ran across having trouble with neg and pos with the tamiya connectors. If there is no standard someone should create one!
  • wickedgmc
    • 823
    last time I looked the top of the "T" was positive and the leg of the "T" was negative, thats how it is marked.
    hopefully that makes sense
    • Mich. Maniac
      • 1456
      yeah makes sense, mine i dont think are marked. maybe they are but I plow right into stuff without directions
      • wickedgmc
        • 823
        you and me both, those direction things you talk of are the things I go back and look at when something does not turn out right :)
        • Gilbequick
          • 140
          They're marked. Look on the side where you solder to and on the flat part of the red where the pins go into the red you'll see a "+" on one and a "-" on the other.
          • Piranha2
            • 320
            they can be either as long as you observe polarity, ie: a Y-connector for packs in series.
            • wickedgmc
              • 823
              they can absolutely be used either way, however there is a plus and a minus on them so you may want to follow that so if you ever buy an assembled pack they will match.
              • ReddyWatts
                • 1756
                Best to keep it standard. The most important thing is that the female connector goes on the batteries. Less chance to short them out.
                ReddyWatts fleet photo
