Tunnel COG
  • chummer
    • 650
    Tunnel COG
    Can somebody tell me where the COG should be for a tunnel hull? Does it balance at 30% like a V bottom?
    "IT IS BETTER TO REMAIN SILENT AND THOUGHT A FOOL THAN TO OPEN YOUR MOUTH AND REMOVE ALL DOUBT"
  • properchopper
    rcgoatbuild@snotmail.com
    • 7708
    Chummer, every hull/setup has its "sweet spot" It takes some trial and error to get it right. Start at 27-30 %. The trick is to combine CG & drive angle & height to keep as much of the hull out of the water [without blowing over] as you can. Test,test,test.
