...the second one I have is for the SUPPO ESC range...I cantcopy and paste the Hi Model one I have...
SUPPO™ Speed Controller Programming Instructions
For Advance programmable Normal Aircraft/Boat ESC
50A/70A/80A/100A/125A/200A ESC
Important Note: these ESCs are all Opto, without BEC to your Receiver, you
need extra power source for your receiver. You can use a UBEC, a voltage regulator, or
extra batteries as the power source for your receiver. If you hear the music tone repeat
again and again for more than 3 times, you may need to check your power source to the
receiver.
Phrases 1 Enter programming Mode
1. Connect your motor and receiver to the speed controller, but do not connect the
battery yet.
2. Turn on your transmitter and move the throttle stick to the full throttle position (full
up). Please Note: Most Futaba transmitters have the throttle channel reversed by
default.
3. Connect your battery and the controller will initialize with a musical tone.
Phrases 2 Programming
After 3 seconds, the controller will start beeping a sequence of tones – a musical tone
followed by one or more beeps. Each sequence represents a parameter that you can program
and is repeated 3 times. The parameters are:
♪— Tone + 1
Beep
Options 1. Cell Type and No. of Cells
♪— — Tone + 2
Beeps
Options 2. Throttle Setting
♪— — — Tone + 3
Beeps
Options 3. Brake Setting
♪— — — — Tone + 4
Beeps
Options 4. Direction and Cutoff Type
♪— — — — — Tone + 5
Beeps
Options 5. Timing Mode
Option 6. PWM setting
Step 1. Starting, Enter Sub-optins. When you hear the sequence for the parameter you wish to
program, move the throttle stick to the Center Position to Enter Sub-options.
The controller will then start beeping a Morse code sequence of short and long beeps
representing the possible options you may choose for the selected parameter. See table 2 for
a list of all programmable options. Each option sequence is repeated 3 times.
Step 2. Select and save, the select the option, move the throttle stick back to the
2
Full-up-position., When you hear the sequence for the option you wish to select. The
controller will then save the selected option, and sound a long beep as a confirmation. It
then goes back to the beginning of the programming sequence (phrases 2).
Step 3. Complete programming and exit programming mode. Setup all the parameters you
need to change. When complete, move the throttle stick to the Lowest (Down) Position.
The controller will save all options and re-initialize in normal running mode so you can start
your motor.
The table below summarizes the various programming options for each parameter:
Option 1.1 Cell Type and Number of Cells
Only for 50A/60A/ 100A-LV / 200A-LV
(LV as 2S-7S)
• — 1 Short + 1 Long NiMh/NiCD Auto Cell Count - 0.8V/Cell
Cutoff Voltage *
• — — 1 Short + 2 Long 7S Li-Po (25.9V) – 21V Cutoff Voltage
• — — — 1 Short + 3 Long 6S Li-Po (22.2V) –18V Cutoff Voltage
• — — — — 1 Short + 4 Long 5S Li-Po (18.5V) – 15V Cutoff Voltage
• — — — — —1 Short + 5 Long 4S Li-Po (14.8V) – 12V Cutoff Voltage
• — — — — — — 1 Short + 6 Long 3S Li-Po (11.1V) – 9V Cutoff Voltage
• — — — — — — — 1 Short + 7 Long 2S Li-Po (7.4V) – 6V Cutoff Voltage
Option 1.2 Cell Type and Number of Cells
Only for 70A (MV as 4S-8S)
Cutoff Voltage *
• — — 1 Short + 2 Long 8S Li-Po (29.6V) – 24V Cutoff Voltage**
• — — — 1 Short + 3 Long 7S Li-Po (25.9V) – 21V Cutoff Voltage
• — — — — 1 Short + 4 Long 6S Li-Po (22.2V) – 18V Cutoff Voltage
• — — — — —1 Short + 5 Long 5S Li-Po (18.5V) – 15V Cutoff Voltage
• — — — — — — 1 Short + 6 Long 4S Li-Po (14.8V) – 12V Cutoff Voltage
Option 1.3 Cell Type and Number of Cells
Only for 80A-HV/100A-HV (HV as 6S-10S)
Cutoff Voltage *
• — — 1 Short + 2 Long 10S Li-Po (37V) – 30V Cutoff Voltage
• — — — 1 Short + 3 Long 9S Li-Po (33.3V) – 27V Cutoff Voltage
• — — — — 1 Short + 4 Long 8S Li-Po (29.6V) – 24V Cutoff Voltage
• — — — — —1 Short + 5 Long 7S Li-Po (25.9V) – 21V Cutoff Voltage
• — — — — — — 1 Short + 6 Long 6S Li-Po (22.2V) – 18V Cutoff Voltage
3
Option 1.4 Cell Type and Number of Cells
Only for 80A-12S/200A-12S (UHV as
8S-12S)
Cutoff Voltage *
• — — 1 Short + 2 Long 12S Li-Po (45.4V) – 39V Cutoff Voltage
• — — — 1 Short + 3 Long 11S Li-Po (41.7V) – 33V Cutoff Voltage
• — — — — 1 Short + 4 Long 10S Li-Po (37V) – 30V Cutoff Voltage
• — — — — —1 Short + 5 Long 9S Li-Po (33.3V) – 27V Cutoff Voltage
• — — — — — — 1 Short + 6 Long 8S Li-Po (29.6V) – 24V Cutoff Voltage
Option 1.5 Cell Type and Number of Cells
Only for100A-SHV-15S / 200A-SHV-15S
(SHV-15S LiPo)
Cutoff Voltage *
• — — 1 Short + 2 Long 15S Li-Po (45.4V) – 39V Cutoff Voltage
• — — — 1 Short + 3 Long 14S Li-Po (41.7V) – 33V Cutoff Voltage
• — — — — 1 Short + 4 Long 13S Li-Po (37V) – 30V Cutoff Voltage
• — — — — —1 Short + 5 Long 12S Li-Po (33.3V) – 27V Cutoff Voltage
• — — — — — — 1 Short + 6 Long 11S Li-Po (29.6V) – 24V Cutoff Voltage
Option 2. Throttle Setting
•• — 2 Short + 1 Long Auto Throttle Range *
•• — — 2 Short + 2 Long 1.1ms to 1.8ms
•• — — — 2 Short + 3 Long Hard Acc*
•• — — — — 2 Short + 4 Long Soft Acc
Option 3. Brake Setting
••• — 3 Short + 1 Long No Brake
••• — — 3 Short + 2 Long Soft Brake*
••• — — — 3 Short + 3 Long Medium Brake
••• — — — — 3 Short + 4 Long Hard Brake
Option 4. Direction and Cutoff Type
•••• — 4 Short + 1 Long Clockwise Rotation *
•••• — — 4 Short + 2 Long Counterclockwise Rotation
•••• — — — 4 Short + 3 Long Soft Cutoff
•••• — — — — 4 Short + 4 Long Hard Cutoff *
4
Option 5. Timing Mode Setting
••••• — 5 Short + 1 Long 1º - For 2-4 Pole Inrunner Motors *
••••• — — 5 Short + 2 Long 7º - For 6-8 Pole Motors
••••• — — — 5 Short + 3 Long 15º- For 10-14 Pole Outrunner Motors
••••• — — — — 5 Short + 4 Long 30º - For 10-14 Pole High-RPM Outrunner
Motors
Option 6.
Pulse Width Modulation(PWM) Setting
•••••• — 6 Short + 1 Long 8KHz – For low RPM and low pole count motors *
•••••• — — 6 Short + 2 Long 16KHz – For most out runner motors
* is Default Setting
receiver.
battery yet.
default.
♪— Tone + 1
Beep
♪— — Tone + 2
Beeps
♪— — — Tone + 3
Beeps
♪— — — — Tone + 4
Beeps
♪— — — — — Tone + 5
Beeps
2
your motor.
(LV as 2S-7S)
Cutoff Voltage *
Cutoff Voltage *
Cutoff Voltage *
3
8S-12S)
Cutoff Voltage *
(SHV-15S LiPo)
Cutoff Voltage *
4
Motors
Option 6.
