porposing?
  • screwball
    • Jul 2009
    • 464
    porposing?
    i just took my new micro scat cat that i just finished building out for its first run and on 3s all the boat wants to do is bounce up and down and porpoise and if i even try to really hit the thottle the torque roll just wants to flip the boat. until i get my steerable outdrive from danny im running a strudder setup that i made but it isnt performing well. my first instinct is to go down to 2s go to a smaller prop and raise the strut, but the strut is as high as it will go i was wondering what you guys thought i should do to settle the hull down in the water. i was also thinking about moving the battery further forward.
    thanks!
    James
  • Flying Scotsman
    Fast Electric Adict!
    • 5195
    James, what motor and prop....3S is probably too much without knowing all the parameters
    Douggie
    • sailr
      • 7128
      move your batteries forward a bit. Sounds like it's stern heavy.
      Mini Cat Racing USA
      www.minicatracingusa.com
      • Eodman
        • 1285
        Search thru the posts for a thread on a magic part for the jolly catamaran, basically a small wedge put on the back end of the tunnel.
        Try this as last resort after trying battery movement etc...
        I know it helped my Twin Jolly but its 35 inches long!
        We did it with a Bang!
        Cats Are Where It's At!
        • Eodman
          • 1285
          It won't help the torque roll --- but it will help the bounce!
          • screwball
            • Jul 2009
            • 464
            thanks guys tommorow im going to try on 2s with the battery moved forward and see how that goes
            • domwilson
              • 4411
              Have you tried changing the strut height, angle, and/or the battery location?
              Government Moto:
              • Rumdog
                • 6667
                The torque roll is probably due to too large of a prop. What kv is your motor? What size prop?
                • screwball
                  • Jul 2009
                  • 464
                  im not sure on the prop but its the stocker from the velocity mono im going to try a metal one i have thats smaller and go down to 2s, the motor is a feigao 380 11s
                  • Jesse J
                    scale FE enthusiast
                    • 7818
                    I agree, strut up, prop down, lower voltage. I did the same thing at first, but ease into that hull,really easy to overpower it.
                    cheers
                    j
                    "Look good doin' it"
                    See the fleet
                    • screwball
                      • Jul 2009
                      • 464
                      ok heres what i did
                      i propped down to a smaller prop
                      raised the strut as high as it would go
                      added 1 quarter ounce egg sinker to the tip of each sponson
                      went down to a 2s lipo
                      results tommorow
                      james
                      • Rumdog
                        • 6667
                        Got any pics of your setup?
                        • screwball
                          • Jul 2009
                          • 464
                          ill try to put up a few tommorow morning before i go to school for now i hjave to go take a 5 and a half hour nap....
                          • Jesse J
                            scale FE enthusiast
                            • 7818
                            Ok, let me back up. Ideally you take one change at a time. Sounds like you changed everyting at once. For the strut, just try to make it a tad above the base of the sponsons ride pad. I have seen those puppies move and they have a bit of nose up, so do some searching and see how others have set theirs up. Once you get close, make little changes at a time, otherwise, you will be back with the dolphins..
                            See the fleet
                            • 6S HYDRO
                              • 1325
                              3600 kv motor- a little hot for 3s with big prop
