Waterproof a lipo pack???
  • RCvolt
    • 31
    Got a couple of lipo that got wet. Stripped the wrap, patted them dry, sat them under a fan overnight and had them sitting exposed for a week. They are as dry as they are going to get and the heat shrinks arrived today. Can I use plasti dip (pictured) to cover the ends after the shrink wrap has been applied? Is waterproofing advisable? Should I be worried about possible moisture retention?Thanks!
  • Ub Hauled
    • Aug 2007
    • 3051
    I think we had a thread about it here somewhere and it basically was saying that "sealing" the packs is not advisable because water WILL FIND A WAY IN and it'll not dry, creating rust and potentially a broken tab or a short somewhere...
    so my advise to you is, seal the hull well not the battery packs.
    I personally sunk many batteries in the water, made sure to dry it out nicely and they worked just fine, you'll find that many people have done the same.
    • RCvolt
      • 31
      Got it I'm glad I got 5 feet of heat shrink
      Thanks!
      • Jeff
        • 233
        Rust? You mean oxidation right. :)
        I try and avoid paste eaters.
        • rcboatmanwithkids2880
          • 348
          insulate & seal'em
          Hi Mate ,
          with my 32' Cat i have insulated the 2x 4s parallel wired & sealed the packs with silicone where the wires protrude through . Considering the amps i run does not allow for over heating , i find this to be a most effective measure in maintaining battery intregity . Works for me anyway .....
          All the best in R/C Boating
          Brad
          Roy Cooper's www.fastonwater.co.uk - Where Brittish Raceboat History Comes To Life !!!
