small props for 3/16 units?
  • SweetZ28
    • 1535
    anyone make small props for the 3/16 size drives?
    I have a 3300KV and used a 40mm prop and then went to a 38mm and it got faster so i am in need of something smaller than 38mm any help will be great.
    O it's for a cat proboat apache 24
    THANKS
    WWW.PPRSLOTS.COM
  • NitroVal
    • Jun 2009
    • 423
    Have you looked at OSE's online store? Octura makes something like 150 props for 3/16", Grimracer makes a bunch, Prather, etc... They aren't uncommon
    The RTR Nightmare- Electric King of Shaves
    Now with 540s- 62mph
    New setup- Etti 150A's, Turnigy 2600s, 5S, X442s and a whole lot of cooling hoses
    • egneg
      • 4759
      The Octura X438 is the smallest prop available with a 3/16 shaft. But I could cut one down a bit if that is what you want to do. The other option is to go to a 1/8 or a 4mm threaded shaft.
      IMPBA 20481S D-12
      • SweetZ28
        • 1535
        Thanks i may have to go with another flex cable with the 1/8 size.
        Thanks for the help.
        WWW.PPRSLOTS.COM
        • Jeff
          • 233
          Y536!
          I try and avoid paste eaters.
          • SweetZ28
            • 1535
            Hi Guy's you know what i did i just put a CF 40mm prop on my drill press and ground it down to 35.5mm and re sharpend it.... will this work is it ok to do this?
            THANKS
            WWW.PPRSLOTS.COM
            • rockwerks
              • Jul 2008
              • 772
              I have taken 4mm props and reamed out the center to 3/16" it has worked well. I use a milling clamp under my drill press... There are tons of 4mm props out there
              an RC rock crawler lost in a sea of boat parts.........
              • Steven Vaccaro
                Administrator
                • 8932
                THANKS
                I've done that and it works well.
                Steven Vaccaro
                • SweetZ28
                  • 1535
                  Cool THANKS!
                  WWW.PPRSLOTS.COM
