how do you u guys water proof you esc's? and what is the process? just bought a mystery 100a and want to wter proof it and ad a water cooling plate that i have. any tips would be great. thnx
water proofing a esc?
Tags: None
big wad o bubble gum and some duck tape
reckon dipping is the sure fire way, but I like to paint so I paint em up with conformal E pox E"Look good doin' it"
See the fleet
paint away, another brand is called liquid electrical tape and it comes with a brushan RC rock crawler lost in a sea of boat parts.........
Coat with DP270 epoxy available here at OSE. http://www.offshoreelectrics.com/pro...prod=ose-dp270Government Moto:
I usually use this to waterproof it, even I use it for my receiver too
I've used bathroom silicone without problem
Ah-Ha!!!!
Cool, that was one of the things I was looking for and the article attached. I looked and looked, but I was looking for epoxy under under the glues and epoxy section, how about that!Originally posted by domwilson View PostCoat with DP270 epoxy available here at OSE. http://www.offshoreelectrics.com/pro...prod=ose-dp270
Thank you.
Brian
Originally posted by Tony View PostDid you get the Platidip at WalMart?
Here's one
http://cgi.ebay.com/ebaymotors/Plast...ltDomainQ5f100
auto parts stores, walmarts, home depot, Lowes, ace hardware etc all carry it. I paid 6.99 a can for the black here in Forks, WA at the hardware store. it also can be used to glue on the cooling plates. Just apply on several thin coats to start then one heavy coat and place the esc on the plate and let set for a couple of hours to set up. then give it another coat or 2
Of course not! these esc's are not designed for our use. The plastidip can usually be stripped off to make repairs (usually) bot at 30.00 why bother.Originally posted by D&D View PostWhat happens after you waterproof an ESC and then it goes bad, can you still send it in under warrenty or for repairs in general?an RC rock crawler lost in a sea of boat parts.........
