Help me figure out the amp.
  • Tony
    • 420
    Hi guys. Please help me figure out the amp draw for this setup. Thanks!!!
    Motor: KB45 8xl 16kv
    ESC: Himodel 200amp 3-7 cel (no bec)
    Batt: 6s1p
    Prop: x445, x646 ???
    Hull: 37"
    I ran the above set up with the x445 prop, and a Turnigy 100amp HV. Esc got pretty hot after two minutes. Should i run x445 or x646 prop with the Himodel 200amp?
    Also, the new Himodel 200 esc has 12 guage wires, 5.5mm connectors. The lipo has 10 guage wires with 4mm connectors. Clip the 4mm off, or make an adator for the lipo?
  • Flying Scotsman
    Fast Electric Adict!
    • 5195
    Tony, that is impossible to state. I suggest you buy an Eagle Tree or similar device, as that is the only way you will get a true measurement.
    Douggie
    • Steven Vaccaro
      Administrator
      • 8934
      I agree with Doug.
      I'd add, say no to the adapter, and use the smallest prop you have and work up with testing. Otherwise, boom. I would also suggest running that motor on 5s.
      Steven Vaccaro
      • Flying Scotsman
        • 5195
        Tony, I am not trying to bash you but you have to figure out hull design, motor condition, drivetrain, power source, wet or dry setup and prop into all the equations of amp draw. There is no simple response to your question
        Douggie
        • Steven Vaccaro
          Administrator
          • 8934
          Its one thing to know the number of amps, its another thing to get to a good running point. Its not impossible to run a boat without a logger. The important thing is not to tax the hell out of the equipment on the first run. Make baby steps in prop increases and you will be ok.
          Steven Vaccaro
          • Flying Scotsman
            • 5195
            Amen
            Douggie
            • ED66677
              • 1300
              the fact is as Steven said 6S is a bit too much, that's 35000rpm+ unloaded!!!
              As for the connectors, go for the 5.5mm.
              Emmanuel
              • Tony
                • 420
                Douggie
                Douggie,
                I know you are just trying to help. No heart feelings. We all have to craw before we can walk right? Just keep it coming.
                Guys,
                Thanks for your advices. Back to the drawing board. lol
                Steven,
                Are you going to restock the NUE 1521 1.5y 5mm any time soon?
                Tony
                • Steven Vaccaro
                  Administrator
                  • 8934
                  Originally posted by Tony View Post
                  Steven,
                  Tony
                  They are on order. Just waiting for Neu to produce them.
                  Steven Vaccaro
