Delta Force
  • nova68
    • Jul 2008
    • 151
    Delta Force
    I have a DF to build,I was thinking of using a Lehner 2250/13T on 8 cell lipos but I think it is getting to heavy, I am open for suggestions. Has any body built a DF and if so what was your set up. so I am confused now I think it's to much motor.
  • Rumdog
    • 6453
    uuuuuuummmmmmm, a DF what?!
    • nova68
      • Jul 2008
      • 151
      DF
      Delta Force 33"
      • Raydee
        • 1603
        I posted on RRR but I will post here too.
        I run a Neu 1521 1.5D on 4s, seems to run great. I have seen that hull with the 1521 1.5D on 5s and its BALLISTIC!
        Team Liquid Dash
        • Flying Scotsman
          Fast Electric Adict!
          • Jun 2007
          • 5190
          Weight is not the problem, as it is probably an advantage with today's power, but that in my oppinion is too much power you are thinking about...run time...props?
          Douggie
          • sailr
            • Nov 2007
            • 6924
            All of us in our club run the 1515/1Y in our DF33's. They are blazing fast. One is running over 60mph on oval racing!
            Mini Cat Racing USA
            www.minicatracingusa.com
            • nova68
              • Jul 2008
              • 151
              With the 1515/1Y how many cells are you running and what ESC are they using?
              • Flying Scotsman
                • Jun 2007
                • 5190
                The million dollar question...what ESC...what is your budget and proposed goals ...high voltage etc. ?
                Douggie
                • nova68
                  • Jul 2008
                  • 151
                  I am open at this time, but I like to use good stuff.
                    • 7277
                    This seems to be the popular setup on most 33's and on 4S will approach 60.
                    Do you plan to race? If so then 4s is the way to go.
                    • Flying Scotsman
                      • Jun 2007
                      • 5190
                      Then you must state your goals....sport...SAW...oval racing...cash ...batteries etc.
                      Douggie
                      • sailr
                        • Nov 2007
                        • 6924
                        4S2P 5000 lipos and Castle 240.
                        Mini Cat Racing USA
                        • TRUCKPULL
                          • 2971
                          DF 33
                          1521 1.5D
                          4S2P - 5000's = 10,000 total - R/C Lipos -30C V2 cells from Pat.
                          X447/3
                          CC125
                          I set the new P Mono 1 mile oval record at the Nat's two weeks ago.
                          Larry
                          • Darin Jordan
                            • 8332
                            BUT... there is something to be said about building a higher-voltage, lower KV motor setup... Less amp draw and longer runtimes being one... There are a couple of decent and inexpensive 6S+ controllers out there that would do the trick, if you are just looking for a nice, fast, reliable sport setup...
                            Darin E. Jordan - Renton, WA
                            • Doug Smock
                              • 5264
                              Originally posted by TRUCKPULL View Post
                              DF 33
                              1521 1.5D
                              X447/3
                              CC125
                              Larry
                              Congratulations Larry!!
                              MODEL BOAT RACER
                              IMPBA President
                              IMPBA 19887L CD
                              NAMBA 1169
