REK Lower units and Snapped Cables
  • bigwaveohs
    • 606
    #31
    Snapped Cables
    I used to run a K&B 0.21 and am planning to go electric with the REK lower. On my K&B I drilled two small holes in the side of the lower unit...one near the top and the other at the stub shaft. I used an epoxy syringe with a small tip to pump "blue" Prather marine grease through the shaft housing of the lower after each race and used the same cable for 10 years...it was still in the lower when I recently sold the boat!
    Perhaps having this way to grease the cable w/o having to take the shaft out after each race would help? Allowing a little "float" also sounds like an excellent idea which I will be sure to do.
    JMHO
    I let the dogs out...
    • 6S HYDRO
      • 1325
      #32
      The old kb 21 just doesn't put out the linear power that these brushless systems create
      • sailr
        • 7128
        #33
        Running in the teflon liner, how did the grease get to the shaft? Those liners seem to shift position from time to time.
        JMHO
        Mini Cat Racing USA
        www.minicatracingusa.com
        • 6S HYDRO
          • 1325
          #34
          Theres no teflon in the rek units
          • sailr
            • 7128
            #35
            I see. Then drilling holes to inject lube is a great idea.
            Mini Cat Racing USA
            • chummer
              • 650
              #36
              Hey Doby,
              How are you making out with this? Have you figured out the problem yet?
              "IT IS BETTER TO REMAIN SILENT AND THOUGHT A FOOL THAN TO OPEN YOUR MOUTH AND REMOVE ALL DOUBT"
              • LiPo Power
                DJI Drone Advanced Pilot
                • 3678
                #37
                Originally posted by chummer View Post
                Hey Doby,
                ...from what I remember last Saturday Doby was able to make few nice runs and no cable snaping!!! I think he is on his last one. Check his video under video links under Kitchener Fun Run from last Saturday...
                Cheers
                Robert
                Canada
                  • 7512
                  #38
                  Hey Doby,
                  Ran 3 times last Sunday and all is well...but then again, its a brand new cable so from this point on, based on my past luck,,,anything could happen.
                  It will get some more run time this weekend so I'll have more details then.
                  • LiPo Power
                    • 3678
                    #39
                    This Saturday?
                    What time? ( 10.30 would be nice )
                    Robert
                    Canada
                    • bigwaveohs
                      • 606
                      #40
                      Cable End Play
                      I'll be using the REK lower...is there a reliable way to determine the "float" (end play) when assembling?
                      • Darin Jordan
                        • 9446
                        #41
                        I'm not sure how to check for it being too short, but if the cable is too long, you won't have any fore/aft play in the stubshaft itself...
                        Darin E. Jordan - Renton, WA
                        • bigwaveohs
                          • 606
                          #42
                          I drilled all the way through...since the teflon liner takes on the "curve" of the lower housing it didn't seem to rotate out of place.
                          I see there is a small hole at the top of the REK lower...looks like a good place to squirt some Corrosion-X and thin out the cable grease a bit for better coverage...
                            • 7512
                            #43
                            3rd run on new cable,,,,guess what happened,,,right,,,snapped cable.............ready to burn this POS REK lower unit.
                            • bigwaveohs
                              • 606
                              #44
                              Thanks...I fabricated a thin nylon washer for the area where the stub shaft seats. Now I can use stock K&B length cables and there is a small amount of end-play in the stubshaft. No need to grind away at end of the flex cables...
                                • 7512
                                #45
                                Ran the tunnel today and guess what............................
                                Any way, I think I found a soluton to the problem....I picked up a OS complete lower unit today.
                                REK=Trash.
