Exactly
Possible solution to battery connect spark??
Yep, I rest my case.Originally posted by domwilson View Post
Charging current is momentary and not enough to erode the contacts at something less than 25v (no heat generated) .
That is of course, unless you do it 100,000 times.
Any dissimilar voltage source (ie: energized vs. non-energized) will cause a spark. This occurs to equalize the voltage between the objects. However the time/current involved will determine the affect on the objects.Originally posted by Boatman View PostSo, is it possible that when there is no load there is no spark right? What if on a HV setup you used a switch heavy duty of course that could be off in line of the neg. side and when turned on no spark, no damage, no worries?
Think of it this way. You move your feet across the carpet with your socks on. You grab the door knob and 'whack' a voltage spark occurs. It is high in voltage and low in current. Your finger does not get burned (current), but you feel the jolt of the voltage.
Actually it can even at lower voltages. It all depends on the current passing thru the circuit. You can try that with a car battery. Connect two pieces of wire one to the positive and the other to a negative. Then momentarily touch the two wires. You'll see how it burns the contacting surfaces. But that's not relevant to the topic. Some people don't like the spark because of one reason or another. Others don't care. It's all about choices for each individual.Government Moto:
I would comment on a couple comments but they might be taken as attacks so i will reply to the OP and the other person asking for the best way or one alternative.
To the folks asking about the what to do. Use a resistor inline for the appropriate voltage and know how to use it or get an esc with anti spark tech.
Using a cap charging spark to indicate whether your esc has bad caps or not is foolish at best, use a multi meter to check your cap during your maintenance interval, thats what it is for.
A spark is indeed the caps pulling amps so fast they jump your plug gap as you get them close together, its not the voltage that does the damage, and the spark (amps) will eventually slam the caps enough to cause failure and erode connectors eventually, and it wont take 100,000 times. Resistors are installed in most high amp electrical circuits today to prevent this fast draw, its called anti spark tech and there is a reason for it.
OP you connect ground last and disconnect it first, thats the proper way to connect any electrical circuit. Indeed a ground will always eat a positive up to the point of load.
And as a couple folks pointed out, in the end do what you want, its your money and equip after all.
I don't think we are afraid of the spark, it is the destruction of the connectors! Frustrating if it happens just as you're plugging in for a race and you can't complete the connection due to the burnt connector. I agree it's easier and cheaper to replace connectors than esc's BUT...
Originally posted by Fluid View PostThe OP's theory doesn't hold water. I get a charge out of reading the demands for "no spark" when connecting the power wires to the ESC. Why is everyone so afraid of a little noise and light? It is the sparking of this connection that signifies the caps are functioning as intended to protect the ESC. Without the caps functioning the ESC will soon fail. If your ESC doesn't spark, you know to replace the caps. It is a method to prevent ESC failure. With care during the connecting process the spark won't damage your connectors, but even if they are damaged, connectors are a lot easier and cheaper to replace than a damaged ESC....
.Mini Cat Racing USA
www.minicatracingusa.com
Makes sense to me. If you plug in once, you have charged the caps. If you unplug and then plug in again (without running the caps down first) then very little spark. Doing it this way is not a true test.
Originally posted by Ub Hauled View PostSo Dom, what da hell does that mean in English?!
Mini Cat Racing USA
YEP! That's what I always do. Just a light quick 'tap' of the edges to dispel the original BIG spark and then plug in the rest of the way. It still erodes the end of the male connector which can make it tough to plug them in all the way.
Originally posted by NativePaul View Postyes, touch the ends of the connectors first before sliding the bodies together, that way the spark erodes the ends and not the outer surface that passes current in normal use when they are fully mated.Mini Cat Racing USA
Theory is great but you oughta see my connectors from just 4S setups...only 14.8V!
That is of course, unless you do it 100,000 times.Mini Cat Racing USA
Somebody posted on OSE that they made up a temporary inline resistor. They use it for the initial plugin...charge the caps...and then take it out and plug in the normal connectors. Little or no spark. Sounds like a plan! I'm still cornfused about the right size resistor to get though!
Originally posted by graill View PostI would comment on a couple comments but they might be taken as attacks so i will reply to the OP and the other person asking for the best way or one alternative.
Mini Cat Racing USA
I too get a spark when connecting at 14.8v. I make the connection quickly and do not hesitate. I have not experienced any contact degradation.Originally posted by sailr View PostTheory is great but you oughta see my connectors from just 4S setups...only 14.8V!
Maybe I'm just fast... lol...
I worry more about the voltage spike to the esc than contact wear.
I will add that this is exactley what tech will tell you at Castle and Joe Ford from castle has mentioned this a number of times in these forumsOriginally posted by Fluid View PostThe OP's theory doesn't hold water. I get a charge out of reading the demands for "no spark" when connecting the power wires to the ESC. Why is everyone so afraid of a little noise and light? It is the sparking of this connection that signifies the caps are functioning as intended to protect the ESC. Without the caps functioning the ESC will soon fail. If your ESC doesn't spark, you know to replace the caps. It is a method to prevent ESC failure. With care during the connecting process the spark won't damage your connectors, but even if they are damaged, connectors are a lot easier and cheaper to replace than a damaged ESC....
.SPRINT CAT 40.........BOOGIMAN 25" MONO 8xl
Originally posted by sailr View PostSomebody posted on OSE that they made up a temporary inline resistor. They use it for the initial plugin...charge the caps...and then take it out and plug in the normal connectors. Little or no spark. Sounds like a plan! I'm still cornfused about the right size resistor to get though!
and I'm pretty sure for a 240HV they suggested 1 ohm 5watts resisterSPRINT CAT 40.........BOOGIMAN 25" MONO 8xl
