Maybe you can get a 3.5mm wheel collar and then drill it out to fit the flex properly? Just a thought. Of course if the flex breaks behind the collar then you will still lose the prop!
flex saver
Someone asked me to post this.
"use a small diameter water line hose to the tune of 3/16" wide to slip, over flex at the coupler end. Saves flex and prop and cable shaft."Steven Vaccaro
so simple and efficient! Great idea!
Originally posted by Steven Vaccaro View PostSomeone asked me to post this.
"use a small diameter water line hose to the tune of 3/16" wide to slip, over flex at the coupler end. Saves flex and prop and cable shaft."Mini Cat Racing USA
www.minicatracingusa.com
