Warning: Trying to access array offset on null in phar://.../vb/vb.phar/bbcode/url.php on line 2 Converting the Chinese square drive stinger to 3/16! - RcBoaters Forum
  • sailr
    • 7128
    You know those BLACK stingers that come on some of the chinese boats? Well, they are the crappy square drive arrangements. I discovered the other day that you can take the shaft out of the stinger and then using the appropriate size punch, drive out the teflon bushings inside it. THEN, use a supervee or speedmaster brass 3/16" bushing in it. Works great! I was about to buy a new stinger for my 25" Prince when I thought there had to be a better way!
    Mini Cat Racing USA
    www.minicatracingusa.com
  • tth
    • Apr 2008
    • 1600
    Nice info Jim I have been wondering about these. Could you please post a pic of your stinger drives?
    Thanks TTH
    • rockwerks
      • 772
      http://www.offshoreelectrics.com/pro...=ros-spdsd-187
      You mean this one?
      an RC rock crawler lost in a sea of boat parts.........
      • sailr
        • 7128
        yep, that'll work...or the one for the supervee stinger. either way.
        Mini Cat Racing USA
        • rockwerks
          • 772
          I just took one apart you can use the drive shaft as a slide hammer and pull the 2 small bushings out the end easily
          • sailr
            • 7128
            Good idea to use the shaft instead of a punch. Thanks!
            Mini Cat Racing USA
            • rockwerks
              • 772
              The speedmaster strut part number is: ros-spds-014-bsf (closest in appearance to aquacraft part)
              The speedmaster stinger part number is: ros-spdsd-187
              The aquacraft part number is: aqub7884
              • sailr
                • 7128
                thanks rock!
                Mini Cat Racing USA
