jb weld heat transfer ?
  • part time
    • 154
    does jb weld transfer heat well? i need to secure these tubes in the heatsink and i dont want to buy the special epoxy if i dont have to.
  • part time
    • 154
    i found that some info that said it works fine
      JB conducts heat better than regular epoxy, but you'll get better cooling with a small fan on the heatsink rather than those little water tubes....
      • FE_Chris
        • 906
        I was thinking I would do this same thing.
        I use a Hextronic 120amps ESC. it is just shrink wrapped. I was thinking I could cut the wrap off, and put a small radio shack 6v fan on it and wrap it back up. Cut the hole for the fan to suck air and BAM! Air Cooled!
        I do have a question about this. The 2 fan leads, where do I plug those in? Seems like I would need a Y cable. My Rx only has 2 channels and a battery slot, and I use all 3 obviously. (NO BEC)
        So Could I splice into the battery leads that plug into the Rx and run a small fan that way?
        Good Idea!
        And I don't know about JB Weld. I was gonna get some artic silver thermal epoxy compound. it's only like 7-8 bucks..... But be carful, it's conductive just a little.
        Fast Electric and Fast Ford's / V8 Mustang Enthusiast
          I use small 12-volt fans and connect the fan wires to the ESC board where the power wired from the battery connect. Just a dab of solder, no need to melt the entire connection. This way the fan is always on. These tiny fans draw so little current your motor will never see the difference. The 12-volt fans can be used with from 6 cells to 18 cells.
          • FE_Chris
            • 906
            Thanks fluid. I am going to look into this I think. I am gonna need something thats for sure.
            So you think the fan is the ticket huh? Then why would everyone else' ESC's have water cooling? Hmmmmmmm....
            • steveo
              • 1595
              maybe to save space and weight and what would happen if that fan stopped working
              • saleens7
                • 1130
                actually Loctite 3876 works well as a heat treansferrer...
                there are a couple of links lower on the thread that explain a little better....
                saleens7, the wookie of rc boating
                • Steven Vaccaro
                  Administrator
                  • 8934
                  Fluid do you have a preference for fans? I bought a couple and so far I'm not impressed with the air flow from them.
                  Steven Vaccaro
                  • SJFE
                    • 4867
                    The little fans I use really turn up when connected to the S-BEC I bought from Mr Hill. They push alot of volume. 3 Racing sells them & the heat sinks I use.
                      Steve:
                      I'm using 12 volt 0.11 amp 30mm fans mostly - labeled Link Depot, etc. Made in China, there are probably a dozen or more different names put on identical fans. Mounted directly on top of the heat sink they work very well even on 8 cells/3S. There are differing quality and fan designs out there, I'm sure some are better than others. There is a big difference in the output of 30mm versus 25mm fans....about 40%.
                      • Steven Vaccaro
                        Administrator
                        • 8934
                        Thanks Jay. I will look for one of those.
                        Steven Vaccaro
                        • part time
                          • 154
                          here is where i have bought fans in the past. http://www.allelectronics.com/index.html the main reasons i dont have on this because im shooting for a 30-40a cont. current and i dont have that will handle 26v.
