Ok Gang,
I ran my N2 sport set up last night for the first time and I am simply not fast enough. My set up is as follows:
Vac-U-Pickle
Hacker 7L
Hydra 120 (Timing is set to High (14 degrees))
5000 mah 2P
I know all of you fast guys run the NEU motors, but I am trying to use the equipment that I have. I was able to get the boat to low 40’s using a de-tongued X642. All of the temps were mid to high 90’s after that run. I have a little angle in the strut (about 1-2 degrees prop down).
I have a few options. I have a Feiago 8L that I can put in it. I can also go back to my Hacker 8S motor that will run high 40’s with an X637…
I would have thought that 50’s would have been easier with a Hacker 7L
Anyone have any prop suggestions?
Thanks
Mike
Vac-U-Pickle
Hacker 7L
5000 mah 2P
Thanks
Mike
