need ammo motor bearings
  • 6S HYDRO
    • 1325
    anyone know where to get motor bearings for ammo motors- they are bigger than the 5mmx10mm ones. please help
  • RCprince
    • Jul 2007
    • 1684
    I believe they are 5x13x3mm or4mm, I use to get mine from the local hobby shop, they were color coded bearing, which these were green.
    Samuel Johnson - “An injustice anywhere is an injustice everywhere.” William Cooper "listen to everything, read everything, and believe nothing unless you can prove it in your own research!"
    • properchopper
      rcgoatbuild@snotmail.com
      • 7708
      Paul, I just pulled a bearing out of a lunched Ammo I had sitting around. They are
      5 X 12 X 4 mm. VBX bearing in California should have them. Good luck getting the non-wire-side endbell off & getting the bearing out.
      • HappyOne
        • 185
        I have a 36-50-2300kv that just died but the bearings are good. Do you want it?
        Grand River Marine Modellers, el Presidente
        IROC VUP, 25" Prince Mono, Mini Hydro, Classic Barrel Back, brushless Mini Rio and two Nitro Tunnels
        • 6S HYDRO
          • 1325
          nah ill get some of my own-but thanks happy. proper thanks for the size now im on my way to the lhs. by the way gettin the end one shouldnt be hard as im not trying to save it so ill just smash it out from the front.
