I have a Delta Force 33 that I want to make faster. It is currently running with a Nemisis 10xl 1668kv on 2-4s in parrell with a x447prop. What should I do to increase speeds higher kv motor, more volts or diffenent prop. Please help
Delta Force 33" Help
Lower the diameter and go to a higher pitch prop. Make sure to monitor temps when doing this. Change the strut angle or if your boat is running wet adjust your CG.
you could try 5s with a smaller prop.NAMBA20...Caterpillar UL-1, P-Spec OM29, P-Mono DF33, P-Spec JAE, Aussie 33" Hydro-LSH, Sprintcat CC2028 on 8s, PT SS45 Q Hydro, PS295 UL-1 power, OSE Brothers Outlaw QMono 4-sale, Rio 51z CC2028 on 8s
All of the above. These types of questions are difficult to answer. The OP has done a great job of telling us his boat and general setup, but what we still need to know is - how fast does he want to go and how much is he willing to spend. You can get that hull into the 70s with enough money, but then it will not be driveable on anything but smooth water. This question is perhaps the most difficult one for anyone to answer, since it requires us to make compromises and it deals with our "feelings".What should I do to increase speeds higher kv motor, more volts or diffenent prop.
