un-joining?
  • screwball
    • Jul 2009
    • 464
    un-joining?
    does anyone have any tips on un-joining a hull and deck?
    i just picked up an old boat at a garage sale and i want to redo it but i would like to get inside of it and really redo it right
    its abs if that makes a difference....
    thanks guys!!!
    James
  • sailr
    • Nov 2007
    • 7128
    Pretty tough on an abs hull without tearing it up. Glass hull is a bit easier. What type of joint does it have?
    Mini Cat Racing USA
    www.minicatracingusa.com
    • screwball
      • Jul 2009
      • 464
      it looks to be glue like ca but im not sure. what method do you use on glass?
      • sailr
        • Nov 2007
        • 7128
        Sorry, I meant what type of seam does it have, flush, overlap, etc? On ABS they likely used a solvent. Pretty much welds the two pieces together.
        Mini Cat Racing USA
        • screwball
          • Jul 2009
          • 464
          it overlaps i was going to trim it down anyway so i might just cut it unless anyone else has any ideas
          • screwball
            • Jul 2009
            • 464
            anyone have any ideas?
            • Jesse J
              scale FE enthusiast
              • 7818
              how about a light saber?
              "Look good doin' it"
              See the fleet
              • screwball
                • Jul 2009
                • 464
                that could work :) is their any type of solvant to cut through ca glue because it could work on this
                • Team FFRB
                  • 328
                  Abs
                  Try using a dremel with a cut off disc and make shore you wear safety glasses
                  HOT RODS ON WATER
                  • sailr
                    • Nov 2007
                    • 7128
                    The only thing that will cut CA will also eat the hell out of the ABS plastic! Don't go there!
                    Mini Cat Racing USA
                    • NitroVal
                      • Jun 2009
                      • 423
                      Yea, I was gonna say, I dont think you will find a solvent that can eat through CA glue without melting the ABS. I would find someone with a bandsaw and try to just cut it off
                      The RTR Nightmare- Electric King of Shaves
                      Now with 540s- 62mph
                      New setup- Etti 150A's, Turnigy 2600s, 5S, X442s and a whole lot of cooling hoses
                      • screwball
                        • Jul 2009
                        • 464
                        thanks guys!!!i have a dremal so ill give that a shot tommorow
