flex coupler or straight coupler??
  • dirtysouth31
    • 546
    ive been searching all over and i finally need some help...i need either a 5mm to .098 flex coupler or the straight kind with set screws on both ends..or a 4mm to .098 flex coupler or set screw
  • Steven Vaccaro
    Administrator
    • 8932
    4 to .098 and 5mm to .098 are odd sizes. What motor are you using?
    Steven Vaccaro
    • dirtysouth31
      • 546
      i wanted a feiago 9l or one i saw online.that one was 4mm shaft..but i just wanted with a ammo with a 3mm shaft
      • Steven Vaccaro
        Administrator
        • 8932
        All those motors will twist a .098 into a pretzel. I would suggest a .130
        Steven Vaccaro
          Your post is confusing, what do you realy want? Why do you want a 9L? The Feigao 540/9L motors have 5mm shafts. What boat are you wanting to put the motor in? The 0.098" cable/little ammo motor suggest a micro boat - is that correct? How many cells will you use?
          BTW I always prefer a flexhex coupler if at all possible.
