motor esc combo question
  • hammertime
    • 513
    what would be a good motor to run with a 60-70 amp esc.....i was planning on running a hotter setup but i decided for what im doing staying in the forties would be my best bet...... i can get a real good deal on a pulso 60a watercooled esc........would the ammo motor with the right prop on 14 cells get me close to my goal if proped correctly
    60% of the time... it works every time!
  • hammertime
    • 513
    by the way this is going into my bk bandit s cat
    • SJFE
      • 4735
      I would go with a feigao 11L.
      • hammertime
        • 513
        wouldnt an xl be better though
        • SJFE
          • 4735
          How big is that scat again. If its 25 to 30 inches long id say a 10 xl...but with a 60 amp limit you may need to prop conservative..
            • 7990
            The L motors are really too small for 14 cells. The Bandit S can run pretty fast - a club member ran an 8XL in his on 12 cells and it was mid-40s with over 2 minutes of run time (all he tried) and probably not over 80 amps. The 10XL would work well I believe. Amp draw as usual is controlled by the prop you use and the boat setup.
            • hammertime
              • 513
              well im just sport running, mostly just fast passes back and forth.....no oval really...... i know prop is the biggest thing for amp draw....... im really just wanting a good sport boat that can reach 40 or more....... i want to run 12-14 cells...... sjfe its a 30" cat......... i really enjoyed my origional setup....got 5 or more min of runtime with 3000mah 7 cell packs.......but speed was only in the mid to high 30s..... maybe a the 8 or 9 xl is my best bet
              • hammertime
                • 513
                fluid could you maybe get some pics for me of your club members setup......would be interested how others have set this boat up
