UL1 programming issue?
  • Jesse J
    scale FE enthusiast
    • 7818
    Does anybody know if you can reprogram the UL1 ESC? It is acting like the low voltage cutoff is set too high. letting you power up to a point the shutting off.
    My proboat ESC would do this and a simple reprogram session would set her straight.
    Anybody have any pointers? and yes, batts were charged...
    Thanks
    J
    "Look good doin' it"
    See the fleet
  • Diegoboy
    • Mar 2007
    • 7444
    I'm interested in this info as well.
      • 7512
      I'm having similar issues with my UL1 controller that I am using in another boat that I just recieved.
      LiPo Power on this forum was having similar issues on his UL1. He was sent a new controller as apparently its related to the capacitors failing.
      • Rumdog
        • 6667
        I'd bet the esc is bad. Same happened to my ul-1 and it was a bad esc. As far as I know, there is no way to program it.
        • Jesse J
          scale FE enthusiast
          • 7818
          I don't see how an ESC can't be reprogrammable. This is exact same behavior as the proboat and all it was was the programming. I don't see how the ESC could be bad, it has done nothing out of the ordinary...
          See the fleet
            • 7512
            Different guts internally. Some IC's (Integrated Circuits) can be programmed, others can't. It all depends on what the manufacturer uses.
            You said it is operating out of the ordinary in your first post. Sometimes when the Caps die, its internal damage and you won't see it physicaly.
            • Doug Smock
              • 5359
              Are you guys adding caps to the UL-1 escs??
              If you're not, add them to your next one.
              MODEL BOAT RACER
              IMPBA President
              IMPBA 19887L CD
              NAMBA 1169
              • Jesse J
                scale FE enthusiast
                • 7818
                K, sounds like I'ma stymied ... sendin her back then.
                thanks guys
                See the fleet
                • pescador
                  • 503
                  I ran on my UL-1 on a windy day, and could only use part throttle, next time out the boat would only run for 30 secs at a time.
                  Look carefully at the cap if the end is bulged at all or there is brown fluid around change the cap.
                  I added 2 that are double the rating of the original and all is good now.
                  Namba District 16
                  1/8 Miss U.S., 1/8 59 Maverick, 1/8 Executone, 1/8 Smokin Joes, MLGSX380, AC Pro40II Q Sport, AC Pro40II nitro,Twincraft mono 10s, Vision AOPC, VS1 FE, M34.
                  • Jesse J
                    scale FE enthusiast
                    • 7818
                    So you sayin you fixed a busted one? what caps did you slap on?
                    if you could link me to em, that'd be cccccoooooollllll
                    See the fleet
                    • egneg
                      • 4759
                      Jesse go here and scroll down to the caps.
                      IMPBA 20481S D-12
                      • pescador
                        • 503
                        Yup them there are the ones.
                        Namba District 16
