Servo mounting
  • M.M.
    • 271
    Servo mounting
    I recently broke my stock balsa servo mount of my boat, and i need to replace it now. Here is what the stock servo mount looked like:
    http://cgi.ebay.com/25-deep-vee-ARTR...3A1%7C294%3A30
    So i tore the old one out, and grinded all of the epoxy off. I am going to lay some FG mat before if epoxy the new servo mount in. But i need recomendations for good mounts. Preferably from here:
    I was thinking this one?:
    Oh and i am using a standard traxxas waterproof servo.
  • kevinlew211
    • 706
    saint paper the servo's bottom and epoxy it down to the hull, its more clean, more safe and save money
    • ozzie-crawl
      • Sep 2008
      • 2943
      being a bit of a cheap skate this is what i do, buy a lenght of alloy angle (see pic) its 32x20x1.4 mm or around 1.26x0.8x0.055"
      cut a piece the same width as the brackets on the servo
      then on the 20mm section cut a piece out so the servo sits in
      you then have 2 pieces siting up just drill 4 holes and its done
      its about $4-$5 for a lenght and you get about 30 servo mounts from it
      • M.M.
        • 271
        I could make one out of angle iron, but i do not know how it would do with the angle of the hull. Plus i would like to use somthing that has tapped holes, so i dont have to use a nut.
        • kevinlew211
          • 706
          you dont have to worry about hull angle, the servo can be set slope down with the hull, but like i said, epoxy it down
          • M.M.
            • 271
            Ok, thanks
            Im going to make one out of angle iron though, because i would like to be able to remove the servo.
            • domwilson
              • 4411
              How about this? http://www.offshoreelectrics.com/pro...rod=dh-jrpa244
              Government Moto:
              • Steven Vaccaro
                Administrator
                • 8932
                I also have some new metal servo mounts I will be listing this week.
                Steven Vaccaro
                • andym
                  More Go Than Show Prop Co
                  • 2454
                  I use these in all my boats http://www.offshoreelectrics.com/pro...rod=dh-jrpa244 I cut a piece of 1/8 light ply. Mark the mounting holes. Drill and use m3 T nuts through the ply, cut the hex head bolts to length, epoxy the ply down with a bit of tape covering the T nut holes. Then just bolt her down. Easy to remove , looks professional ans makes removale of said servo easy!
                  • Jesse J
                    scale FE enthusiast
                    • 7818
                    I use the aluminum angle bracket ozz mentioned, I wouldn't epoxy it though, if it fails you may damage the hull removing it. If you go with glue - use sillycone it holds and the servo is still removable when (not if) it fails.
                    "Look good doin' it"
                    See the fleet
                    • M.M.
                      • 271
                      Jesse what do you mean by dont use epoxy? Are you talking about just epoxying the servo down, cause i am not going to do this. But i am going to make an angle iron bracket, and i was going to fiberglass it into the hull with some fiberglass cloth and resin.
                      • M.M.
                        • 271
                        Well i made a nice aluminum bracket, and i need to attach it to the hull. What is the best way to do this? I have some epoxy that i could use, or i can fiberglass it into the hull. Which would be better?
                        • domwilson
                          • 4411
                          Maybe some double sided tape?
                          Government Moto:
                          • ozzie-crawl
                            • Sep 2008
                            • 2943
                            i usally drill a few holes in the base part off the bracket, then epoxy it down.
                            i usally do mine at the start of a build so c/f then goes over the bracket when doing the rest of the inside. but you could just run a piece of cloth over it and glass it down
                            • M.M.
                              • 271
                              I did drill some holes in the bracket. So i think i will glass it in, because i dont want the expoxy to fail like it did with the previous mount. So are there any secrets to glassing the mount in? I have some fiberglass cloth and polyester resin.
