I have two builds going right now. A new P-spec Raptor and Phil Thomas Stealth. I want to use a Hitech HS-225mg in both. Will the 225 work or do I need to use a full size servo. Thanks for the suggestions.
Is space a real issue here? I prefer full size servos in general, but you can try the low profile ones :http://hitecrcd.com/products/servos/...-servo/product
Pricy but powerful: I use one in my Outboard Tunnel---S9551 Low-Profile
S9551 Low Profile
FUTM0661
Volts Torque Speed
4.8V 98 oz-in (7.0 kg-cm) 0.14 sec/60°
6.0V 122 oz-in (8.8 kg-cm) 0.11 sec/60°
spacer
Dimensions Weight
1-5/8 x 13/16 x 1 in
(41 x 20 x 25 mm) 1.6 oz (45 g)
I agree with T.L. I generally stick with full size servos whenever possible. I prefer the tried and true hs-645mg on 6v bec, but i've got a JR z4800s to play with in my villain on 6v. I personally wouldn't run the 225 servos. I always strip the gears in them. I like T.L's suggestion.
Here's the 225 specs:SPECS: L: 32.4mm x W: 16.8mm x H: 30.8mm (1.27" x 0.66" x 1.21")
Transit: 0.14sec/60° (4.8V) 0.11sec/60° (6.0V)
Torque @ 4.8V: 3.9 kg-cm, (54.2 oz-in)
@ 6.0V: 4.8 kg-cm, (66.7 oz-in)
Weight: 31g (1.09oz)
COMMENTS: The replacement metal gear set is HRCM6396
I have had a pretty much 100% success rate using the Spektrum Digital servos. The S6020 is generally powerful enough for any of your standard 4S applications.
full size is the way to go....I have a couple of the s6030's in the stock pile and they are great servos....I have not had the best of luck with the hitec 645's on my spectrum dx3r pro and mr3000 recivers....but that just may be my radio problem...they seem to dance left and right all by themselves ...you might try some traxxas 2075's but they do have plastic gears I beleave....
I used Hitec exclusively for years. 225mg on anything under 12 Nimh. I use full size on everything now. Maybe for a 2s boat.
Recently I gave the Savox a try. Good grunt to dollar ratio and can be had water proof. I don't have enough laps with them to vouch for their quality but they've been good so far.
Saving weight was my goal. I know it's only grams but I would think reducing weight all adds up to better efficiency and performance. These are my first race boats but I know I have to focus on dependability also.
Give this a try: I had the same issue with this combination ( radio/servo)
Hitec also makes a digital version of the 225 that is likely more reliable for the Raptor. Space is limited in riggers. Don't sweat the weight though. Especially in a Stealth. I ended putting my Stealth on a high fat diet to keep it on the water.
I tried a Spektrum S6020 at one point and it had "slop" in its own gear mechanism. Is that normal, or is that out of spec? There was enough free slash that the wiggle it allowed in the outboard it was attached to was concerning.
Both Savox waterproof servos I have tried since have been better in that respect. SW-0231MG and SW-1210SG.
I use Futaba S3305, it has an almost imperceptible slob in it as well, they are in the same price range. For my set ups so far that slob has not affected my control, and I also used one on my outboard and didn't seem to bother, it's hard to tell w/o first hand experience.
I run a HS-5245MG in a full P JAE rigger. I didn't have the choice of running a standard size servo with this boat but the boat turns stupid sharp with the mini. Use a standard size if you have the room but if your set up is good, a smaller servo can work on a P-Limited rigger.
