hitech servo bad
  • ron1950
    • 3082
    hitech servo bad
    bought a hitec 645mg for one of my boats ...installed as usuall and when i started the boat up....it had the shakes bad....chattered back and forth wouldnt quit etc..tryed it outside the boat ...same no improvement so tryed another reciver same no change.....is there a repair station for hitech servos or chuck this one out the window? thanks
  • lectriglide
    • 540
    Hitec has great service on everything I've dealt with them on.
    Hitec RCD offers precision servo actuators with superior engineering for airplanes, helicopters, boats, and robotics. Shop our proven selection today!
    • Doug Smock
      • 5359
      Are you using a Spektrum radio?
      MODEL BOAT RACER
      IMPBA President
      IMPBA 19887L CD
      NAMBA 1169
      • ron1950
        • 3082
        yes doug i am but i have several hitechs that work well with it so far lol
        • Doug Smock
          • 5359
          I had a similar issue. I had also used them for years without issues but................http://www.youtube.com/watch?v=98_U9eC4sM8&feature=plcp
          Now this same servo has been flawless with the MR300? The guys at Spektrum recommended a device that will fix this issue (low voltage as I recall). Let me see if I can find it.
          Do you have a non Spektrum radio that you can test that servo with?
          Doug
          MODEL BOAT RACER
          IMPBA President
          IMPBA 19887L CD
          NAMBA 1169
          • ron1950
            • 3082
            no all my radios are spectrum....mine is much worse then the vid lol...tryed a mr200 and a mr3000 both the same
            • Doug Smock
              • 5359
              This is supposed to be the cure, but I haven't tried it. http://www.horizonhobby.com/products...-booster-SPMCP
              Darin can give you more information about it.
              Doug
              MODEL BOAT RACER
              IMPBA President
              IMPBA 19887L CD
              NAMBA 1169
              • ron1950
                • 3082
                doug did u send the servo back for repair or use the low voltage thingie
                • Doug Smock
                  • 5359
                  That servo is still in operation with a different (Futaba) radio. I used a Spektrum servo with the MR200 and haven't had any further problems (thanks Darin).
                  You may or may not have a bad servo. It could be a compatibility issue as in the video.
                  It would be nice if you had someone local with a different radio so you could test it before you send it back.
                  Oh, something else that was strange. (Forgot that was in the video also) The servo worked perfect in the throttle channel. Try that just for giggles and let me know what you find.
                  I know where you're at. I was pretty frustrated for a bit cause like you, I hadn't seen that problem before and I've used Hitec servos in everything.
                  Doug
                  MODEL BOAT RACER
                  IMPBA President
                  IMPBA 19887L CD
                  NAMBA 1169
                  • ron1950
                    • 3082
                    i had it installed in a inaccessable aera of a new jersey skiff....took a few hours and alot of bruses on my hands to get the darn thing out and put a jr servo in....lots of cussing too....lol...guess i will go back to traxxas 2075 or get a few more jr servos
                    • Doug Smock
                      • 5359
                      If you don't mind, just for grins see if that servo will work properly in the throttle channel. I'm curious!
                      Thanks Ron.
                      MODEL BOAT RACER
                      IMPBA President
                      IMPBA 19887L CD
                      NAMBA 1169
                      • ron1950
                        • 3082
                        yup worked in throttle position but could feel it shaking slightly in my hand but arm stayed still
                        • Doug Smock
                          • 5359
                          Interesting. Thanks Ron!
                          D.
                          MODEL BOAT RACER
                          IMPBA President
                          IMPBA 19887L CD
                          NAMBA 1169
                          • properchopper
                            rcgoatbuild@snotmail.com
                            • 7708
                            FWIW I started out with the 645MG in tunnels - seemed like the go-to servo at the time. Had the buzzing/stuttering prob and the gears stripped way too easily (yup tunnels are hard on servos I'll admit). While they're designated as a MG or "metal gear" servo, the metal gear that constantly lost teeth was thinner than a piece of paper and the rebuild kit was $18 or so. For that kind of money I started buying HK or HP servos that were way stronger and never looked back.
                            As far as working on the impossible to reach JS internals, I'm training my pet hamster to use simple hand tools to get inside and make adjustments.
                            • properchopper
                              • 7708
                              I can totally relate : I had my arm jammed hard inside my skiff holding a transom nut when the UPS driver knocked. Pulling my arm out to answer the door would have taken time, and I needed to be carefull since I had fresh artwork on my arm. I answered the door and had to sign the UPS document with my left hand (I'm right-handed) as the UPS driver looked on at a human-alien with, instead of the usual two arms, had one arm and one boat . I didn't bother to explain
