Need info on "Servo Savers"
  • properchopper
    rcgoatbuild@snotmail.com
    • 7708
    I've seen these critters advertised , seems mostly for cars. Thing is that my tunnel will flip & the resultant pull when the lower unit slaps the water takes out my servo. Is it possible to adapt a servo saver to my application with a push/pull servo arm ?
    Thanks,
    Tony
  • HOTWATER
    • 2419
    Hmmm....not sure about this, but does seem like a good alternative to loosing servos. Are you looking to obtain one as I should have one or two laying around? I know the one's I have are made to fit Futaba servos...LMK...
    -Kent
    "Will race for cookies!"
    IMPBA D12
    • properchopper
      • 7708
      -Kent
      Kent, I'm using servos that take Futaba arms. Would it be possible to show pictures of how they mount/fit ?
      Thanks,
      Tony
      • HOTWATER
        • 2419
        Thanks,
        Tony
        Sure!...here are a couple of bad pics (LOL!) of one mounted on a Futaba servo...
        IMPBA D12
        • Doug Smock
          • 5359
          This may work for you Tony. http://www.servocity.com/html/122ss_double_end.html
          I have seen guys use quick links (less the screw), fuel tubing, and lock collars.
          The boat is hauling the mail, Herb would be proud!!
          Good luck!
          Doug
          MODEL BOAT RACER
          IMPBA President
          IMPBA 19887L CD
          NAMBA 1169
          • properchopper
            • 7708
            -Kent
            According to what I see, it seems like I could get one to work. What kind of a transaction do you have in mind ? Edit : OOps, I'll need a double arm like the one Doug suggested, $ 6.95 at servo city; I think I have about that much left after WW VII !
            • MaxCorvette
              • Feb 2010
              • 12
              Here is a pic of how I did something like this..
              In this case it is for a throttle servo for a gasser that vibrates pretty bad.
              Marcel
              • Himalaya
                • Apr 2009
                • 259
                Out there are shaft type servo savers for rock crawler trucks. I use to have those in my G1 crawler. You made think they might be suitable for boat rudder links too. Surely they are a bit thick thus may need some mod in the rubber boot.
                • properchopper
                  • 7708
                  Where can I find them ?
                  • siberianhusky
                    • Dec 2009
                    • 2206
                    how bout this one, for over 200 oz/in servos.
                    • properchopper
                      • 7708
                      Originally posted by siberianhusky View Post
                      http://www.tcscrawlers.com/Ofna-Heav...r-p-16255.html
                      Thanks. The one Doug suggested looks more applicable since I use a push/pull config rather than a single arm. I'm giving the "fuel tubing" solution some thought as well.
                      • Anbjorn
                        • Apr 2009
                        • 255
                        If it was me I would consider trying one of these used in large scale rc cars.
                        Here is also one
                        With ball bearings
                        I will require some modifications to your steering system but the saver is very durable and accurate.
                        Anbjørn
