waterproofing a receiver
  • HappyOne
    • 185
    I can't seem to find 3M DP270 very easily here in Canada. Are there other products that I can use that will be easier to source?
    Grand River Marine Modellers, el Presidente
    IROC VUP, 25" Prince Mono, Mini Hydro, Classic Barrel Back, brushless Mini Rio and two Nitro Tunnels
  • domwilson
    • 4411
    You can get it here... http://www.offshoreelectrics.com/pro...prod=ose-dp270
    Government Moto:
    • HappyOne
      • 185
      Thanks but it is about $20 to get Steve to ship something to Canada so that makes this some pretty expensive stuff.
      • Rumdog
        • 6667
        Just use the ol' baloon trick. Always works well for me!
        • RPC1
          • Apr 2008
          • 125
          I just use epoxy. Hit it with a hair dryer to make it flow.
          • Brod
            • 196
            I connect all wires etc then wrap it all with plastic electrical insulation tape,it makes it very waterproof and helps vibration a bit.
            Spending a good 10 mins. or so makes a fine,neat job.Plus its easy to remove,if needed.
            Brod..
            Slow gets boring fast.
            • 785boats
              Wet Track Racing
              • 3423
              I'm with Rumdog.
              A balloon costs 2 cents & takes 30 seconds. Why complicate things with anything else.
              Paul.
              • russmustar
                • Feb 2009
                • 20
                Traxxas make a nice waterproof receiver box for the 1/10 truck called the Slash. I have one in my truck, but I think it would work well in a boat. It retails around $12. Russ
                • Jeff Wohlt
                  • 2740
                  As I have said many times....CONDOMS works best. Also, a camping soap box also does a nice job.
                  Balloons have too small of neck. Condoms need to be used that are non- lubricated. Zip tie the end and you are done. You must remove them at the end of the day because of condensation.
                  www.rcraceboat.com
                  jwohlt5362@yahoo.com
                  • russmustar
                    • Feb 2009
                    • 20
                    The only problem with using condoms or balloons with the FAST Futaba system is that they have a tendency to warm up while being used and if you "bag" them they will overheat and fail. Russ
                    • Jeff Wohlt
                      • 2740
                      hmmm...I have had a few almost smoking and they never gave up! :)
                      www.rcraceboat.com
