abs repair/ receiver pack
  • Doug Smock
    • 5359
    Originally posted by Mich. Maniac View Post
    WOW! that pic of your 4th grade pic is on a couple billboards in my town for a real-estate company! thats funny stuff
    Whats up with that????
    Yankees, you can't trust them. The real estate co.has obviously been thumbing through the year books from Mayfeild Elem.:rolleyes:
    I lived in Lapeer Mich. for most of my childhood.:)
    Doug
    MODEL BOAT RACER
    IMPBA President
    IMPBA 19887L CD
    NAMBA 1169
    • boater76
      • 574
      Wow thats looks fubar! Have you had any luck fixing it?
      Ken
      • Jeepers
        • May 2007
        • 2050
        I have made some progress this last couple of days!! I roughed up the inside of the hole with a sanding drum, cleaned it with soap and water, then used a wax&grease remover to remove any oils. I used a shaped piece of pink foam, coated in waterproof epoxy, I also coated the inside of the damaged area in epoxy then inserted the foam. Then I took some 3 ounce hi power rocketry grade "glass" cloth and inserted it between the abs and the foam working epoxy in to the "glass"with a stiff brush. let cure for 24hrs, sanded smooth , and using automotive glazing putty to fill in any imperfections( blue stuff in pic). the repair is very solid probably the strongest part of the boat:D now i am sanding to remove most of the paint as it was badly damaged in the crash. hoped to get it painted by this coming weekend.
        ps here is some pics of a "small" rocket my friend Jason(pictured) and I are working on,this rocket will be fully finished in carbon fiber when done.(this is were i get my glass cloth from) the engine casing in the next pic is 29" long 54mm dia. the rocket is 7 ft 6 inches tall 6" dia. :D just thought I would explain the hi power rocketry comment in the above post:D
        • Jeepers
          • May 2007
          • 2050
          almost complete! just waiting for my lettering, and some few minor touch ups, and it will be on the water this weekend!:D
          • Doug Smock
            • 5359
            #35
            Wow, great repair job Jeepers!!!!! The rocket is pretty cool too.:D
            Doug
            MODEL BOAT RACER
            IMPBA President
            IMPBA 19887L CD
            NAMBA 1169
            • Jeepers
              • May 2007
              • 2050
              #36
              Doug
              Thank you Mr Smock!
              • longballlumber
                • 3417
                #37
                Jeepers,
                Is that a speedmaster rudder assy that your using? What strut did you use?
                Thanks,
                Mike
                • Jeepers
                  • May 2007
                  • 2050
                  #38
                  Originally posted by longballlumber View Post
                  Jeepers,
                  Thanks,
                  Mike
                  Yep its speed master got it off this site! I am using an octura 3/16strut for .130 flex cable, but its set up for wire drive.
                  • Jeepers
                    • May 2007
                    • 2050
                    #39
                    Finished
                    FINISHED cant wait to get it on the water:D :D
                    • boater76
                      • 574
                      #40
                      Excellent rebuild! I like the skeleton guy at the helm.
                      Ken
                      • Jeepers
                        • May 2007
                        • 2050
                        #41
                        Ken
                        Thanks I cant take credit though it was my wifes idea for the "theme".
