Tactic receiver goes up in flames !
  • properchopper
    rcgoatbuild@snotmail.com
    • 6958
    The UL-1 speed control puts out 5.2 V from the BEC circuit and apparently is designed to be compatible with the Tactic Rx since the UL-1 comes that way. It also outputs 2 amps. The Castle BEC was putting out 6V [ I metered it] although it can put out "up to" 10 Amps according to it's label. This was a pretty serious meltdown and I'm still a little baffled !
    • Blackjack-sven
      • Feb 2009
      • 371
      I'm guessing that there was a closed short within the Rx when it got wet allowing all 10amps from the cc bec through all at once. I've seen this happen a few times before. Also, the pic you show above shows that the heat generated from whatever went through the bec port.
      HK Genesis, DF Vortex, Baja 5T, Lazer ZX-5 sp, XXX, 8T, P51-D Mustang Shangrila, GP Giant P51-D Mustang, Blade 400 3D, with way too many more to list.
      • properchopper
        • 6958
        I'm inclined to put this explanation on top of the list of probable causes. Thanks for the input.
        • theShark
          • 25
          The tactic is marketed for Cars, Trucks, Boats, Nitro, Gas and Electric so its more than likely it can take 6V
          • LuckyDuc
            Team Ducati Racing
            • Dec 2008
            • 989
            I have 70 + runs on my Tactic Rx in my UL-1. I have a an external ParkBEC supplying 6volts to it. No problems here. I think you had a short and it dumped 10amps into the Rx all at once.
