Hello guys was today trueing the new Futaba T4PM with R304SB RX and had some curing of signal about 100m any body have answer? Posible problem of RX better R334SBS
Problems of range with Futaba T4PM
The R334SBS has a dual, diversity antenna, which could improve your range. The R304SB has only the single antenna. Was the end damaged by chance? It should be stripped back 31.2mm. How high above the hull does the antenna extend?Vac-U-Tug Jr (13mph)
Hello in theory is all good and the antenna is 40cm and comes out approx 25-30 from the hullOriginally posted by fweasel View PostThe R334SBS has a dual, diversity antenna, which could improve your range. The R304SB has only the single antenna. Was the end damaged by chance? It should be stripped back 31.2mm. How high above the hull does the antenna extend?
Enviado desde mi ELE-L29 mediante Tapatalk
Sorry I just saw after medid we have approx 220mOriginally posted by RafM View PostHello in theory is all good and the antenna is 40cm and comes out approx 25-30 from the hull
Sounds like you already replaced the stock short antenna with a longer one. You might check that the antenna is still connected to the board inside the receiver.Tyler Garrard
NAMBA 639/IMPBA 20525
T-Hydro @ 142.94mph former WR
