Spektrum tx/rx reception issues
  • kevinpratt823
    • Aug 2012
    • 1360
    Frustrating day at the pond today........ I have Sprektrum DX3C/mr200 in 4 boats, and some days are better than others, and some boats are better than others.
    Notice I said reception, not range. You see, I can usually go pretty far out in distance, but there are a couple spots at either end of the oval I run, at both ponds I go to, where my signal drops out, I mean like almost the exact same spots..... and I'm not talking real far away, less than 100 yds. Today it was particularly bad, and I actually had to paddle all the way to within 20' of the boat, hoping something didn't smoke, before I got it back, which was a good 4-5 minutes dead in the water. Sometimes the Whiplash is the worst offender, but today they all did it, repeatedly. Some with RX packs, some with external bec, glass hulls, wood hull, all have antenna tubes, all had the second wire out of the hull, good tx batts, I've tried everything. I am going to try my DX4R Pro that I use for cars, but other than that, I'm at a loss. I know some use aircraft radios, but I'm all set with sticks......I have read that Futaba is superior, and I am finally at the end of my rope to where I'm willing to look into that road and switch them all over. I'd hate to do it, because Spektrum has been great to me with customer service, and has performed great in my cars, not to mention the 6 or 7 mr200's I own... Nobody else runs boats here, so nobody else to compare to. I am beginning to wonder if the residents around the pond are conspiring against me and jamming my signal to discourage me from running there, the tinfoil helmet I made protects my brain from their signals but my boats are still vulnerable......it also could be aliens.
    I have been dealing with it for a few seasons, and it doesn't seem to be a brown out, I can run a tighter oval with repeated back to back turns without issue, and it usually sits dead in the water until it drifts out of the "hole", taking far longer than an esc reboot. I am sick of wading or walking around with my radio up in the air trying to get it back.
    I should also add that, I run from 2 different spots at both ponds, pretty far away perpendicularly from eachother, running a different oval, and I still seem to lose it in roughly the same areas. The Whiplash will actually cut in and out while carving through the turn sometimes, quicker than an esc reboot....can't be good on electronics...
    Anybody experience this "Bermuda Triangle/Black Hole" effect? Is Futaba really a cure?
    Thanks for any input, I'll let you know if the DX4R Pro works any better when I get a chance to try.
    -----10/25/14-----Edit/Update-Used a Futaba today, it was WAAAAAY better than the Spektrum. It was the farthest I have ever driven my boats, and I had to go pretty far out of my comfort zone to get it to cut out, but even when it did it was only for a split second. Freedom at last!
    My private off road rc track
  • rightturnonly
    • Jan 2009
    • 143
    Kevin,
    Try one of these..I think it should fix the problem..
    The Spektrum Voltage Protector from Spektrum, the leader in spread spectrum radio control.
    John
    JOHN A. GROSS
    MILLBROOK, AL
    Crickety Crack Racing Team
    • Luck as a Constant
      Make Total Destroy
      • Mar 2014
      • 1952
      for some reason i get the feeling like certain radio brands work better in certain areas of the country than others. and visa versa.
      i think trying a futaba is a good idea.
        Make Total Destroy
        • Mar 2014
        • 1952
        also kevin, you had range issues when you ran with me last year, here up at the Hopkington state park... i think a new radio brand is in order. can't hurt to try one. whats the return policy if its no better?
        • kevinpratt823
          • Aug 2012
          • 1360
          I have a couple to give a shot, but like I said, I can run back to back turns in a tighter circle no problem, and this thing sits dead for several minutes sometimes. A capacitor only really helps with momentary brown outs, I run them in all my cars, this thing sits dead for several minutes sometimes, it's not just rebooting the esc. I should not need that with an rx pack anyway I don't think, but I'll bring one next time. And I have also bought the Spektrum signal booster to no avail, it is my understanding that those aren't intended to help with this anyway, I think they are more for airplanes running dual servos and such, pretty sure they only boost the middle signal wire.....It also doesn't make sense for brown outs that all 4 boats are drastically worse on a particular day, and that it seems to cut out even when going straight in those areas....
          • kevinpratt823
            • Aug 2012
            • 1360
            Not sure on return policy. I'm going to make some last ditch efforts and try a few things, mainly my DX4R Pro and a capacitor and see if it's any different, maybe even some alkaline batts in the TX to bring the voltage up compared to the rechargeables, and a 6 cell RX pack.......
            • kevinpratt823
              • Aug 2012
              • 1360
              Just realize, with the Mr 200 if you are running a receiver pack or external bec there are no open ports to plug in a capacitor.
              Sent from my SCH-I535 using Tapatalk 2
                I'm going through reading all the posts and I'm thinking I bet this guy is using rechargeable batteries in his transmitter. Yep. That's 1.2v lower total voltage than alkaline. I don't think I even need to say it........
                  Btw, if you decide to switch. ...I would like to buy a marine receiver or two from you. So pm me if you decide to. Thx
                  • kevinpratt823
                    • Aug 2012
                    • 1360
                    Just got back, tried some alkalines, they were in my bag so not new, but brought voltage up to 5.2v, no difference. Rechargeables with a fresh charge is 5.1v, and mine get swapped before they hit 4.8(they were 5.1 today) as I have a few sets. Even new alkalines only get you to 6-6.1v and only for a little while, KFXguy did you notice a big difference with them? If that's it then you must have to change them often..... Tried the DX4R Pro back to back with no major difference either. 2 different boats, 1 with 6v rx pack(full charge), one with external bec, with 2 different radios, cutting out in the same spot, even when going straight.........Wish I had a fresh set of alkalines with me to try, but if that is the difference, and this tx won't work properly below say 5.5v, then I am still considering switching.........
                    I rrun the same rechargeables in my car radio, and have never had a problem with my 1/5 scale Losi 5ive-T, and I cover just as much ground I think.
                    Are any of you guys using rechargeables in your radios without issues?
                    At what TX voltage do you experience problems with signal loss?
                      • 5660
                      If you do switch over to Futaba, please post back you findings, I like to know as I have my own Bermudas but I run Spektrum ( with antenna tubes) and Tactics , now phasing out the latter. I don't have the Futaba in my agenda as of now. The radio which is unfazed by this, not once affected is a FlySky, but I am not going to elaborate on that. I have been thinking about Futaba however...
                      BTW, no CF hulls, only wood and FG ones...
                        Man I never ran rechargeable batts. But I did have issues once when I had ran down alkalines.
                        • kevinpratt823
                          • Aug 2012
                          • 1360
                          Do you remember how far down they were when you started to have issues by any chance?
                          I would think that 5.1v should be within operating range, if not then that's a bummer for Spektrum...Charging some packs now, may try and go test the theory today, if not then maybe after work this week.......
                          Considering Spektrum actually makes and sells thesehttp://www.spektrumrc.com/Products/D...ProdID=SPM9525
                          Advertising as-
                          "Spektrum’s new rechargeable 1500mAh NiMH AA batteries are ideal for powering the Spektrum DX6i and DX5e 2.4GHz DSM2 transmitters or any other transmitter that uses AA batteries. Each package contains 4 individual 1.2V NiMH AA cells."
                          You would think it should be within the operating range.......
                          • 427srule
                            Racer
                            • 164
                            Kevin,
                            For years I used Airtronics and had glitches here and there and lost races because of it.
                            In February I purchased a Spektrum DX4R Pro and 8 MR3000 receivers to convert all my boats.
                            It started out as a nightmare and again had glitches. I called customer service and found out my Transmitter had an older program in it so I quickly updated it.
                            They also suggested using voltage protectors which John suggested above.
                            I haven't had a problem since then even on the offshore course at the Nationals.
                            Check it out...I hope it works for you.
                            Thank you,
                            Mike
                            • kevinpratt823
                              • Aug 2012
                              • 1360
                              Thanks 427, I'll see about updating the DX4R Pro, but the DX3C won't have that option I don't think, and really shouldn't need to IMO, others are doing just fine with it. And as far as the voltage protectors, I'll have to get some Y harness', as I have all MR200's, which only have 3 ports, the third is used by the rx batt or bec. Thank you for the input, maybe I'll try to have a chat with customer service as well.
